I got it from https://tozalazz.com/ but you can order it directly from amazon.
Comes in a nice carry case that fits everything.
Here's the compressor itself. Everything about it screams "quality!". Heavy duty carry handle, wide metal plate on the bottom (helps prevent tipovers), rubber feet underneath, and dual piston design! I hadn't heard of dual piston till I started looking at new compressors recently, but I'm a believer; it doesn't get hot and is FAST; to the tune of 11.65CFM. That means you can airup 330L/min at 0 PSI.
Long hose with quick connector on one end and standard Schrader valve on the other.
Comes with Schrader to Schrader quick connect adapter.
Comes with some standard attachments.
This compressor is so powerful, you have to connect it directly to your battery. *insert Tim the Tool Man grunts*
Connection to 12v is easy for the hybrid. The best part is the long air hose can reach any tire on the truck. No more cigarette lighter fire drill exercise to get to different tires.
I was shocked, but it's actually quieter than my old compressor.
The best part, it fits perfectly under my back seat.
If you're in the market for a compressor, you can't go wrong with this one. This is the best one I've ever owned. Highly recommended.
