Tailgate trim plastic rivets
Prickly Pear
Pacific Northwest
24 Maverick XLT CG, 92 Ranger
Ford Maverick Tailgate trim plastic rivets PXL_20260401_221403904
+1 for the rivets recommended by @jfgesquire. Perfect fit and they look like parts Ford should have used in the first place. If I wasn't so lazy I'd just replace them all before they fail, but by the way the OEM parts look that won't be too long! Here is the broken part I found in my driveway
Prickly Pear
Pacific Northwest
I haven't even thought about them, so I just went out to look and take a picture. They haven't moved a millimeter. They are the right diameter for aesthetics and the right length to fit securely.
To me they look like they could have been OEM.
Edit to add.... They are still press fit, they just look like Phillips head.
Not trying to be contrary, but the core pin is indeed threaded. They are meant to be pressed in for installation, but the pin can be backed out by turning it counter-clockwise. I verified this by visually seeing the pin is threaded, not serrated, and backing one out after pressing it in. This makes these fasteners removable/reusable. Cheaper and better than OEM!
DannyUncanny
Dan
Maverick XL
For anyone else trying to size these guys. The panel hole is nominally 7.2 mm diameter 0.9 mm thick, the slotted plastic trim is 1 mm thick and the OEM rivet is 6.8 mm diameter before pushing and expanding the core.
Anything sized for a 7 mm hole should work.
jfgesquire
Hamburg, NY
2025 Maverick Lariat
But if the head is too wide in diameter it looks wrong extending past the recessed area where it sits.
BlueStreak
IL
2025 XLT with 301A 4K Tow & Co-Pilot360 1.0
Got a 2025 Hybrid AWD XLT in April 2025. Installed Tonneau in Sept and awhile later noticed that most of the upper trim rivets on the tailgate trim were missing. Ford replaced them under warranty, but wouldnt give me a free supply. April 2026 I noticed another rivet missing. Dealer will fix under warranty and we discussed there should be a better design and fix. The fasters should be designed to last more than a few months.
Tbone91
Fulton, NY
2024 Ford Maverick XLT FX4, 1991 Chevrolet Camaro RS
Not the best pic, I just blew it up from another pic I posted. For $11.31 tho I bought a bag of 500 random pieces off Ebay and found ones that fit fine and seem to be holding after a load from my aunt's garage and a dump run. Not the exact replacement as they are screw heads but they fit well and are holding down my Lasfit tailgate cover 👍 even if they come out there's a few more in the bag of randoms 😅
Ford Maverick Tailgate trim plastic rivets Screenshot_20260612_231148_Gallery
