Tailgate Assist mod recommended?
Cancunbadlands
Cancun
Cancun
Cheap option from Amazon
Ford Maverick Tailgate Assist mod recommended? 20250710_171954
Ford Maverick Tailgate Assist mod recommended? 20250710_174308
lee
quebec
ford macerick
I had one off Amazon that broke the very poorly welded nipple off after just under 2 years. I replaced it with a DeeZee unit from the dealer that is a lot better welded. If you get the one from the dealer, it has a 2 year warranty for $20 more than the same price off Amazon. One downside of the DeeZee shock is that it opens very, very slowly in below-freezing temperatures.
Hi 👋
I did the exact same thing as you.
I originally bought a cheaper, well-reviewed version from Amazon , I won’t name the brand , but I’m replacing it with the Dee Zee.
The main reason is the nut 🔩 that goes inside the tailgate. The Dee Zee hardware seems much better. The nut on my Amazon tailgate assist failed and ended up scratching the paint.
Question for everyone: what do you think about spraying the back of the tailgate assist bracket with a thin layer of rubber coating before installing it? My thought is that it might help prevent the bracket from scratching the tailgate paint once it’s tightened down. Or should I forget the rubber and attach it directly?
Hi 👋
I feel the rubber sandwiched in between is only going to allow that bracket to rotate.
If the bracket is attached properly and tightened using a properly fitted Torx plus 45 bit. The bracket won't move / rotate and scratch the paint.
Ford Maverick Tailgate Assist mod recommended? 20260921_100641
lee
quebec
ford macerick
I agree with you
the deezee is best because of the nut that goes inside the tailgate.
The nut seems custom compared to the other tailgate assist I had originally bought.
tpollauf
Toledo/Port Clinton, Ohio
1992 F-150, 2009 Pontiac Vibe GT, 2026 Maverick Lariat Hybrid
lee
quebec
ford macerick
Attached are photos showing the different bolt types used with each tailgate assist. The DeeZee is the one pictured on the brown table.
The DeeZee design preventing the bolt from twisting. So does the other bolt but it moved a couple times so decided buy the new deezee
Ford Maverick Tailgate Assist mod recommended? IMG_3121
Ford Maverick Tailgate Assist mod recommended? IMG_3120
