Suggestions For Front Plate Mount Bracket?
pxpaulx
Minnesota
You can try asking the dealership to not install the front plate mount and tell them you have an alternate solution you prefer to use.
Granger did that for me. I've posted my solution for an FX4, others would have to do something else. Just got my plates earlier so I plan to post pics shortly (will add here in addition to my original thread).
pxpaulx
Minnesota
Nightowl
seattle wa
2022 Maverick Lariat
Jukebox Nero
Carl
Draper, UT
2021 Ford Maverick Lariat Alto Blue FX4 4k 2.0 EB
This looks great! Looking forward to your review. 👍🏼
Looking forward to your review!
I received the mount today. Looks good for what I needed. To attach in the Tow Hook area, the hook would need to be removed. I wanted it centered and it works great for that:
Ford Maverick Suggestions For Front Plate Mount Bracket? PXL_20211016_211038539
Ford Maverick Suggestions For Front Plate Mount Bracket? PXL_20211016_211019650
Ford Maverick Suggestions For Front Plate Mount Bracket? PXL_20211016_211054545
Ford Maverick Suggestions For Front Plate Mount Bracket? PXL_20211016_211125098
Ford Maverick Suggestions For Front Plate Mount Bracket? PXL_20211016_212436329
Ford Maverick Suggestions For Front Plate Mount Bracket? PXL_20211016_212306743
It was a little costly, but it attached to that lower grill nicely. On a related note, the dimples for drilling are located on the unpainted part. You can see them if you look on most of the photos.
JazzyJockJeffcoat
MD
Chevy
Any wobble or shifting? The way the mounting hooks are thrown over the grill slats looks prone to movement. Unless there is another point of contact that I can't see.
Mabcim
Rochester, NY
I like the location, but wonder if it’s blocking the active shutters.
Jukebox Nero
Carl
Draper, UT
It locks down pretty tightly. The backing for the bracket has foam on it, so it helps to keep any wobble out. The left/right shift is prevented by the small dividers of the lower grill.
Not sure, but this is the same black, only slightly lower than where the default dimples would've put the plate.
Spook
Central KY
Maverick Lariat Hybrid
I may be wrong and I'm sure you will tell me if I am but for those states that require front plates, mounts should be supplied from the factory and installed. If your state does not require them, why should Ford put them on? That is just an extra cost. Of course, as shown above, many of us like to put our own stuff on the front and now have to figure out a way to do it.
Here's one that will crank some of you up: License plates are just that, plates. They are not "tags." Tags have a string on them to hang on a product for sale or provide info.
Big_T
T
2022 Maverick XL Hybrid
Ford doesn't install them, the dealer puts them on at PDI. Unless you tell them not to. They are a no cost option. Some dealers don't even order them if not state required.
Nightowl
seattle wa
I really appreciate the photos and review. Thanks!
mdl20813
Idaho
Cactus Gray Maverick XLT
My pics aren’t as nice 😂 but after taking @Jukebox Nero ’s lead, I can also vouch for the mount. Solid quality and mounts up nicely in the center.
Ford Maverick Suggestions For Front Plate Mount Bracket? 00EF2576-A590-4950-924A-8AB461206EBF
Ford Maverick Suggestions For Front Plate Mount Bracket? 56C7C841-867B-4390-9ADD-2306171F6214
Ford Maverick Suggestions For Front Plate Mount Bracket? B8177611-AF22-4034-A6FB-421A46B38B56
Ford Maverick Suggestions For Front Plate Mount Bracket? 3744A31E-84D3-4989-9EBD-75B4ADFF5C88
donkiboy
NJ
none
Did you also buy the exact one in that link? That one points to SKU: CS-AC105-852, which shows BWM 3 series 2006. That SKU along with all grill mounts on there are sold out.
Rob Cactus Gray
Robert
Sierra Vista AZ
11 Prius
My dealer will have to drill it anyway sigh…can’t be sold here without it.
attach it with magnets first and figure it out later.
