Strut tower brace Steeda
little kenny
kenny
wisconsin
2024 ford maverick tremor
has anyone bought one from sheeda for your maverick and is each end sppose to be the same angle ?? mine dosnt seem to be the same on each end
little kenny
little kenny
kenny
wisconsin
Well does your Steeda, it look like this...
Passenger-Side
Drivers-Side
Jerry
yes mine look like that i just didnt installed cus each in is at different angles not sure if it sppose to be like that or not will check angle after work got an angle finder at work
Fcnrwy
Jerry
Wisconsin
Maverick XL Area 51
The angle is determined by the original bolt location (angle).
You are replacing one of the front strut bolts with a (supplied longer one)..
Jerry
little kenny
little kenny
kenny
wisconsin
Yes I have the bolt that come with it just wanted to know if mine was defective or improperly manufactured before I install. The angle on the end steel different. I’m smart enough to know I don’t know enough and should ask question. Sorry about the e bad spelling for steeda
MAGPLM
Michael
Maple Grove, MN
2022 Bronco Sport Badlands & 2023 Maverick AWD FX4
Have it on both of my vehicles. Works fine, and looks like that.
Fcnrwy
Jerry
Wisconsin
Maverick XL Area 51
What is its purpose? Why would you need this?
It is NOT a mandatory thing. It is simply a Strut (support) that connects the two Front Suspension towers and helps keeping the body "stiff".
Which means, Less body flexing that occurs overtime.
It was a common thing to add to early Mustangs.. My Brother had a few...
Installing one doesn't hurt... :wink:
Jerry
You could always order another one.
Compare the two side by side.
If they are identical. Then keep one and send one back.
The probability that you would be sent 2 defective braces, would be highly unlikely.
Unless you already know the proper angle.
What will using a angle finder due?
Good luck.
GB
Ford Maverick Strut tower brace Steeda IMG20240902095209
agmonaco
Tony
Pittsburgh
2024 Ford Maverick Hybrid
Jerry
Thx
Blue_Max
Orlando, FL
It reduces body flex, which tightens up handling. Reduced flex also helps keep things from working their way loose due to the constant flexing.
