Stop courtesy lighting from coming on at drive-in
SteveV
Mentor Ohio
2022 Lariat
On a 2022 Lariat I'm looking for someone to tell me how to stop the outside lighting from coming on everytime you open the doors. It's NOT the button above your head in the interior, that just stops inside lights from coming on. When you are at a Drive-in you don't want all the outside lights to come on when door is opened or just starting the engine for heat or charging.
🤔 Police dark mode?? Accessible through ForScan.
Good Luck
zach57x
FL
2022 Maverick XLT
Man I wish I could get mine to come on lol
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
Just let the battery drain to 50% and keep it under that all the time, problem solved. 😂 J/k
There is a setting in the driver info screen to stop lights from staying on after you open the door, but I've never played with it.
SpaceCowboy
2022 Ford Maverick Cactus Gray
That's a safety feature that most new cars do. There won't be a button to turn that off. Like others have said ForScan is probably your only option.
Should be a way. You can turn off courtesy lights early with push of lock button on fob but takes a second or two.seems like there is I length of courtesy delay in settings somewhere. I cannot check my mave now.
Ok went and checked in my Lariat. Go to settings, vehicle, lighting, auto lamps then choose "OFF" and OK that.
Choices are off, 10 or 20 or 120 seconds.
Works on XLT's too.
It seems police mode is to darken the dash and interior lights.
Thank You
Timothyd
One thing I miss from my older vehicles is an "OFF" position on the lights switch.
