Spring-Loaded Flex Bed Divider
3D Pro
O'Fallon, MO
2023 Ford Maverick
I like the Flex Bed, but with the side tie downs and a hard tonneau cover clamped on, but I found it hard to maneuver a 2x6 into the rear slot. I could have easily made a hinged board to fit, but decided on something more versatile.
Using a double thickness of 3/4 plywood I created a spring-loaded divider that could be used several places.
Pictures attached show it In the back slot, upper slot and even 90 degrees to the tailgate. I use it primarily to hold 2 Roughneck containers that give me maximum height with the tonneau cover closed.
Ford Maverick Spring-Loaded Flex Bed Divider 20240824_100455
Ford Maverick Spring-Loaded Flex Bed Divider 20240824_100542
Ford Maverick Spring-Loaded Flex Bed Divider 20240824_100634
Ford Maverick Spring-Loaded Flex Bed Divider 20240824_101101
dmopro
Richardson, TX
That is SWEET!!! But my old brain is having a hard time visualizing the spring (compression springs?) that must be sandwiched between the two sections of plywood. Very nice, very nice indeed.
MichaelHigh
Colorado Springs, CO
2023 Maverick Hybrid Lariat
Details. We need details. Drawing? How are the springs mounted? Etc, etc, etc. Pretty please.
3D Pro
O'Fallon, MO
2023 Ford Maverick
Here are the basic dimensions I used, make the 2 parts and invert one of them. use 2 short (1.25 length) 3/8-16 screws but don't tighten them so tight the boards won't slide. Attach a stretch spring between the eye hooks and as you push the board ends together the spring has tension.
Ford Maverick Spring-Loaded Flex Bed Divider Spring Board Assy
Mr Pibb
Vegas
2024 Lariat
Which bed cover did you go with? I'm liking that the clamps don't block the rail.
3D Pro
O'Fallon, MO
2023 Ford Maverick
I am using the Bakflip mx4 tonneau cover
nillwj
Walter
Davison, MI
2025 Maverick Hybrid AWD
Elegant. I might make two of these. Thanks for sharing! 🙏
