Snow Tires Does size Matter
GaryM
Latham NY
2024 Ford Maverick Hybrid
I Have the 2024 Maverick Hybrid with 225/65R17 on truck..
I have a new set of 215/50R17 -91T snows sitting in my garage
Any Idea what type of issues i could have using these??
Clarkdonbran
According to my wife, size matters!
NoVaJimmy
KCMO
Lexus GX 460
RedRider
Kitchener, Ontario, Canada
Ford really appreciates people running smaller diameter tires so they run through their warranty mileage quicker. The speedo is already optimistic by about 3% from the factory in their favor....
Take a look at the wear rating for equivalent tires with just more narrow and wider rubber. You will note that the tire width has almost nothing to do with tire life. Wider tires will float more in winter and in mud, causing loss of control, while narrower tires will tend to cut down to solid surface, but have less rubber on the ground for grip. They both wear about the same in cornering. Wider tires are mostly a lot of hype, and the only things that really matter are compound, tread pattern and siping.
NoVaJimmy
KCMO
Lexus GX 460
I'm not talking about tire wear or tire warranty, I can assure you that I know all about tires. I'm talking about your vehicle's warranty. It's 3 years 36k miles and 5/60 for powertrain. Since the speedometer is 3% optimistic you are actually putting more miles on your odometer than your vehicle is actually traveling, aka, your warranty will run out faster than it should based on mileage.
TheSEARCH
ford
What is the diameter of the snows you have? That is key NOT the width. Tire Rack can be used to look up factory tire diameter and if they carry the snows you have then they have that diameter listed too,. I wouldn't use them if its off by much. Maybe a tenth of an inch at most. Funny thing I have Bridgestone Blizzak WS 90 snows which according to Bridgestone are exactly same diameter 28.5 as factory tire yet they are 2 MPH slower.
Oh the factory tire gave ME exactly right speed according to two separate gps units I have for mph , maybe odometer not perfect no idea. . Not sure where your getting its 3 percent off from factory NoVaJimmy ???
Optimus
MN
2023 XLT Hybrid
Have you put the 215/50R17 next to your truck? It’s tiny! It’s going to look like a temporary donut or worse. Spec-wise it’s 3 inches shorter. You’d LOSE 1-1/2 inches of ground clearance immediately, which would be the last thing I’d want to do in a snowy climate (not sure where you live). The 215’s are also over 1-1/2 inches narrower theoretical sidewall bulge (tread itself is only 0.4 inches narrower). Simply standing the tires next to each other should be obvious to see the differences. The 215/50R17 is on the order of several sizes smaller than stock. Not to mention your speedo would be reading about 11% too fast. You can compare specs between sizes on numerous tire size calculators online, or by looking at factory specs on a tire manufacturer’s website.
Not even an option.
