Snow and Front Wheel Drive
DanielP
Daniel
Mechanicsville, VA
Ford Ranger XLT
I haven't driven in the snow with only front wheel drive. Would appreciate any insights or unusual problems others have had. We live on top of a fairly steep grade.
Hi Dave, front wheel drive is hands down better than rear wheel drive on snow covered roads as long as you are not driving down a mountain and don’t perform a sudden down shift right before a right or left turn since this may result in a loss of traction and thus the car will not properly trac through the turn. Tap your breaks instead. Lastly, you are better off with front wheel drive on a Maverick truck anyway, since there is little weight in the rear of the truck. Hope this helps. By the way, I’m originally from Switzerland and as an 18 year old I learned how to drive in the Alps, LOL.
Tom 71 Maverick 24
Northeast Ohio
Tires are the key. Get something with good tread, preferably 3-peak snow rating. You don't necessarily need dedicated snow tires, but that's not a bad option if you deal with a lot of snow in your area.
I've driven rear wheel drive cars, front wheel drive, and 4 wheel drive in the snow. Tires make the difference in all 3.
Of the 3, the RWD cars were the most fun, because you can steer the rear wheels with the throttle, which many today call drifting (or fishtailing, power-sliding, or power-induced oversteer). But as I've grown older, I am more inclined to just want to get to my destination unscathed.
FWD is generally superior in traction due to a higher percentage of the vehicle's weight being on the drive wheels. With my RWD vehicles, I've always put something in the trunk/bed in the winter to add ballast over the drive wheels (which helps a lot). My 4WD vehicles have been great in the snow, though you do have to avoid getting that false sense of security that makes you think you're invincible.
todd92
Todd
I don't know if it's been mentioned yet, get snow tires and you'll be fine.
boxster03
michael
santa fe NM
2023 Maverick XL Area 51
As everyone said a good set of winter tires will be your friend
Mike S
Naples, FL
Escape, Ecosport
69 years old and driven in snow all my life. FWD means all the weight is in the front and none in the back, so you have no traction in the back. Never had to change tires. Just use all season radials. Most important is be aware that you will lose traction in snow and ice. The car or truck will slide, so you have to drive accordingly. When you turn the wheel the car might take a second before it grips and the car starts turning. I personally think rear wheel driving is better than FWD, but then I am used to driving a Volvo and not an Escort. Weight over the wheels makes a big difference.
I've had a Ford Escape with FWD for many years. Never had any problems. Note that most of my driving was in the city & hwy.
Prior to switching to Fords, my wife had a BMW rear wheel drive sedan. That was an absolute disaster in the winter.
Ozarkbeard
...don’t perform a sudden down shift right before a right or left turn since this may result in a loss of traction...
OP has a hybrid with the eCVT. They won't be down shifting because they can't. The hybrid transmission doesn't have gears.
The Hybrid's Slippery mode should help in snow.
DanielP
Daniel
Mechanicsville, VA
Ford Ranger XLT
Well, are you sure because all Mavericks have what’s called a “gear box” designed for seven different speeds. I just read the following: “According to Dawn McKenzie, Ford Trucks communications manager, the 2025 Ford Maverick features the latest Ford hybrid transmission – the HF55. The HF55 gearbox has a higher torque capacity than the HF45, which was previously used in the 2022-2024 Ford Maverick Hybrid, as well as the Ford EscapeHybrid. As Ford Authority previously reported, the latest master contract agreement between Ford and the United Auto Workers (UAW) union reveals that production of the HF45 is slated to end at some point in the future, meaning that it will presumably be replaced by the HF55 altogether.”
zen_
24' XLT
If I visited the snow and didn't necessarily live somewhere where it snows, I think all-weather tires are a good compromise. Other than that, nothing can beat dedicated winter tires when having to drive through snow squalls regularly.
If I was sticking to paved roads, I'd prefer a FWD car with winter tires over a 4x4 truck with all-terrains.
It would be interesting to see how something like the Michelin Cross Climate 2 stacks up against against a snow tire in just snow, but the snow tire is still going to have better performance on ice with a softer compound optimized for winter, and covered in sipes.
I was happy with the Goodyear WeatherReady (gen 1) on my previous vehicle, other than the ~10% fuel economy penalty and they got very loud after 30k miles.
Carlitos_92
Yes, he’s sure. :wink:
I don’t see anything of value in that long quote, but the hybrid eCVTs and EcoBoost transmissions are not nearly the same. I guess “gearbox” can be applied to both flavors, but only in the most general sense.
dochawk
doc
Las Vegas
My best advice would be to move to a more reasonable climate--snow should be a destination, not a weather condition!
:crackup:
During my exile, I lived in a house on a block built in about 1900 (i.e., before working folks had cars).
The alley to the street was steep enough that in winter, both with my crown Victoria snd then the e150, I would get a running start, drop the throttle as I hit the long ice patch and coast to the street, where I would then gun the engine, causing it to spin about 30 degrees as I hit the top.
I don't miss that at all!.
whitef
Frank
Kansas
Lost count...about 20.
FWD Maverick with Blizzaks on it is a snow wizard. Mud too.
The "slippery" mode helps a lot too. About to swap the Blizzaks on for the winter.
slashsnake
Minnesota
Tesla model 3, Kia Soul Xline
Get winter or winter rated all season tires if you drive in it a fair bit. I've used Michelin's Crossclimates on my car and they are wonderful in snow, and good for all year round (though not efficient tires, your MPG will drop a little).
Other than that, FWD is great in the snow, it's not AWD, but I had an 86 Ranger RWD in Colorado... I'd get a railroad wheel assembly that weighed probably 400 lbs and throw that in the back every year in winter and it was still less than fun.
onemuir
Tod
Portland Oregon
2024 Ford maverick
I have driven in snow a lot with two different FWD cars, first was Geo Metro and second is my current Ford Focus. In both cases as long as you don't get behind people who have no business on the road in those conditions they do very well. Stopping with them was never a problem but getting rolling from a stop is an entirely different matter. You have to use a very light foot and even then you can actually feel through the steering wheel as either the left or right tire gets a little slippage. I did get into a habbit of buying new tires just before the snows came.
I am so looking forward to having AWD on my Maverick for sure. I once had to drive from Dodge City Kansas to Trinidad Colorado in a blizzard and I was in my Jeep since I was expecting the snow storm. I drove it as long as possible in just 2WD so I didn't get to over confident in it but eventually had to put it into 4 hi it was getting so loose, I passed two snow plows and lots of traffic heading east but the west bound lane was by now covered in deep snow. At one point came to a town that had plowed all of its lanes and had to go back to 2WD. After clearing that town got back onto nasty road surfaces and kept having to get off the gas with rearend getting loose, finally realized I hadn't placed it back into 4 hi... As soon as I pulled the lever it started driving like the road was clear again. So anyway the point is while you can get around with 2WD/FWD if you know how to drive in snow there is just nothing like the feeling of having all four wheels doing their job in the heavy stuff.
Holy cr*p! The world’s first 10,000 pound Jeep! That had to affect the steering. Gas mileage and ride.
SLINGSHOT
Charles
NE Iowa
2017 RAV4
'69 SAAB, '74 SAAB, '80 Citation, ' '05 Sentra, '10 Vibe, '16 Camry, '17 RAV4, '23 Maverick.
All were FWD except for the RAV4. All driven in Northeast Iowa. Can you say SNOW? What happened between 1980 and 2005? No FWD needed in Floriduh.
A lot of rear wheel drive vehicles mixed in there in Iowa. You DO NOT need FWD or AWD to drive in snow. Pull your head out of your butt, turn off the phone, slow down. OR, yap with one hand, drive with the other and HAMMER DOWN.
In my MANY years of driving, I have seen a LOT of cars in the ditch in the winter time. The VAST MAJORITY were Four Wheel Drive pickups and Jeeps. As the song says, "It warms the cockles of my heart."
Do I ever feel sorry for them? HELL NO. They always remind me of the videos showing NRA instructors shooting themselves in the leg or foot, HILARIOUS.
