Skipping/Jerking Wiper Issue Saga Continues - New Motor Did Not Fix
RyanS93
Ryan
Syracuse, NY
XLT Lux EcoBoost AWD
I have been dealing with the skipping/jerking wiper issue now since I bought my truck. I am starting to see it cropping up on many other people’s trucks too and hoping we could discuss what could be causing it.
What I'm referring to is only when the wipers are on intermittent mode, when they reach the end of the cycle to rest at the bottom of the windshield, they seem to skip/jerk ahead to a further stop rather than resting at the original point. When the windshield is dry it doesn’t do it and when using the regular low/high or washer modes they work perfect as well. I have checked and my wipers are aligned to the marks on the windshield, and I have even gone through a couple sets of blades and cleaned the windshield.
I have had it to 2 different dealers who could not replicate the issue. So based on feedback from other owners, I went ahead and just replaced the wiper motor myself. It’s an easy job and I had Ford points which made the part cheap enough to be worth the gamble.
The wipers are doing EXACTLY the same thing as before. I’m completely stumped now and all I can think of is this is either an inherent design flaw or maybe it’s the wiper linkage that’s to blame? I have no idea and this issue drives me absolutely crazy. Would love some input from other owners on this!
Added some videos as well to explain (note not all videos are mine).
Silver23
2023 Ford Maverick Lariat
I believe they are just "parking" . It's what they do at the end of the cycle when turning off and apparently in your case on intermittent too.
RyanS93
RyanS93
Ryan
Syracuse, NY
That’s what I assumed as well, but they don’t go all the way down to where they normally park when you turn them off, just a little bit further. Perhaps this is “normal” operation.
Silver23
I went and tried mine, they don't do that. It's a 2023. Maybe it's a quirk of some of the trucks? Very strange.
I can't see what else you could do other than changing the motor. The good news is I doubt the wipers will fail because of this although it would be annoying for sure.
Rolmav
Kansas City
2025 Maverick
Maybe it's the wiper switch giving a bad signal on the intermittent setting? That's my shot in the dark.
Maverick2023
Kip
Atlanta, GA
Toyota Rav4
Normal to me and I don’t lose sleep over it
Tailender
Will
Poconos
Mine does it too. Built April 2022.
RyanS93
RyanS93
Ryan
Syracuse, NY
This makes sense to me, I notice the same thing with it shifting the position of the blade rubber. I also feel like when I tried a different set of blades (Rain-X Latitude) the problem seems to go away or at least get significantly better as when it does that weird “park” motion, the new blades seemed to glide better rather than “thunk” like the factory Motorcraft blades. I have cleaned the windshield several times with Invisible Glass and Windex, but thinking maybe those cleaners aren’t working right.
I am going to try to deep clean the windshield with a different glass cleaner and install a new, different set of wiper blades, since it seems to be the worst with the Motorcraft blades. I am going to try the Rain-X Silicone Endura blades. I wish I could get Bosch Icon but they don’t seem to have ones that are compatible.
I am also thinking maybe a coating of Rain-X would make the windshield more “slick” and reduce the drag?
Skifletch
Buffalo
2023 Maverick XL
I believe I asked in the other thread and don't recall if there was a reply. Do we know what kind of motor drives them? Is it by chance a stepper motor? It looks almost like a step.
My 2023 EB does not do this. I find myself wondering if it's a sensor, or motor driver issue. Also maybe there's the wrong downward spring force on the blade?
RyanS93
RyanS93
Ryan
Syracuse, NY
I am not well versed enough to say for sure but I don’t think it is a stepper motor. Only my guess. I assumed a new motor would fix it but it did not. It’s possible that the force on the blade isn’t right somehow. I had to remove the wiper arms for the replacement so I would have re-torqued the nut on them and they behave exactly the same as before.
