Shock tower brace improves stability on handling?
Blue_Max
Orlando, FL
If you drive so fast you think you need a strut bar to keep you from crashing, you should have your drivers license revoked.
No one is installing a strut brace for crash prevention.
Chops
Lobo
With that said, I don't believe that a strut brace provides much of a benefit on a vehicle that has the strut towers attached as close to the firewall structure as the Maverick.
Strut brace so close to firewall will reduce rattles from dashboard flex in the hard plastic dashed Maverick.
Damn, I’m appreciating my strut tower brace more & more each day!
Chops
Lobo
fastgascar
Vince
Gilbert, AZ
2025 Ford Maverick
I am sure it helps support the deflection of the top of the shock towers, but it would be even more effective if it also attached to the firewall.
Six Foot Pickle
Ger
San Bernardino, CA
2025 Maverick Hybrid XLT
I have a 2025 ford maverick lariat hybrid.Do you think a shock tower brace improves stability on handling at all? Or is it a waste of money? Let me know what you think. Thank you!
Will you be driving your truck so hard around corners that you think you might weaken or break the shock tower? What kind of person drives their Maverick that hard that they have to worry about things breaking underneath???
Blue_Max
Orlando, FL
This was the question:
How did you get "weaken or break the shock tower" out of that?
A strut brace is an enhancement. Are people who enhance the sound deadening in their Mavericks afraid road and wind noise will burst their eardrums?
Tbone289
Not likely, but I don't have any dash rattles.
r0tax
CO
2025 Lobo 402A VB
There are MANY false statements in that text. I'm assuming that is an AI response, and a shockingly bad one.
Welcome to AI, hallucinate with AI, you'll get all the answers you seek! It should be a requirement to note when a reply is AI generated. ><
Chops
Lobo
I’ll usually footnote the AI I use - ie “Per Grok”
Lately I’ve noticed that Grok answers match Googles word for word. Is one copying the other or is their a Master AI telling them both what to say I wonder.
Phimosis
Larry
Santa Clarita, CA
Waste of money.
The Maverick unibody is already stiff and it’s not very powerful, especially the hybrid.
If you think back to cars that really needed strut braces, unibody cars of the 1970’s, like the Fox body Mustang, yeah, it was a floppy wet noodle. And it was pretty easy to cram 400 hp into the engine bay. A triangulated strut brace made a huge difference in Fox Body handling and was totally worth the expense and effort to install it.
Fast forward 50 years and we progress from the era of slide-rules to the era of CAD design with torsional rigidity simulations. Nowadays you’ll see minimal handling improvement in a modern car from a strut brace, because the body is already stiff from the factory.
If you’re modifying your car for track use? Sure, have at it. The stiffer chassis may gain you a tenth of a second per lap.
For street use? Waste of money.
asylus
George
TEXAS
'24 Ford Maverick Lariat Tremor
Though it was for the Bronco it was something I had come across when considering the brace and wondered why they kept saying easily disconnect for off-roading.
Tbone289
The only concern could be if you bottom out the suspension hard (high speed) and the force of that is transferred through the bar to the other strut tower. There are online examples of off-roaders adding strut tower braces for their benefits if you care to search for them.
Keep in mind that my point was to explain that strut bars don't affect off-roading negatively and the AI made false statements. Prior to that, I also mentioned that I don't think there is much benefit in having one on a Maverick. It certainly isn't going to improve off-road performance to any degree.
Let's also keep in mind that flex in a body-on-frame vehicle is not at all the same as flex in a unibody chassis.
Chops
Lobo
Surely a waste of money for you, Phimosis - because you would not benefit from the confidence gained from the placebo effect.
However, are appearance mods a waste of money? Some argue yes, some argue no.
I’m going to remove my blue strut brace and paint it with some red caliper paint:)
Not painting my dual piston calipers however - can’t see them behind my Turbofan wheels.
Phimosis
Larry
Santa Clarita, CA
Chassis flex effectively increases suspension travel in low speed off-roading.
With a very stiff chassis, you run out of suspension travel sooner, start lifting tires sooner and run out of traction sooner.
If your body has significant flex to it, you will be able to keep your tires on the ground longer, IE your ramp-travel-index will be better.
In theory, a strut tower brace would make the chassis stiffer and decrease your RTI, which is an indicator of off-road prowess.
However…. If you add a strut tower brace to a bronco sport, you will most likely not be able to perceive any on-road benefits.
likewise, you would likely
Not be able to perceive and off-road detriments.
I’m betting that if you took 2 identical Bronco Sports, or Mavericks for that matter, and equipped one of them with a strut tower brace, then double-blind tested dozens of drivers to see if they could figure out which one had the strut tower brace, I’m going to bet that it would be a coin toss. Half would get it right and half would be wrong. Because it makes so little difference as to not be noticeable.
brucecorporal
bruce
SASKATOON
escape
I noticed a difference in my first sweeping corner going onto the freeway-you have to pay attention but i noticed it right off-just a touch of more....stability? when cornering at speed-kinda hard to explain but not to feel.
