NedF
BC Canada
Indeed.
As long as you have decent cell service, the trucks not in deep sleep, and you don't mind waiting a few minutes for the app to respond at times.
It's too bad they don't add Bluetooth connectivity to the app so you can do functions like unlocking using your phone without cell service when you are within 10 - 15 feet.
fordvideoguy
fordvideoguy
Salina, KS
www.long-mcarthur.com
2022 F-150 Lightning, 2021 Ford Bronco
Hi all, this appears on my 2024 Maverick XLT 300A Equipment Group Package.
I'm assuming that's the keypad or am I mistaken?
That's wrong, looks like the copy and pasted from 23MY.
OLD guy
Guy
Scherrerville IN
2019 Ranger
Just one thing to add to any string.....My wife has noticed a lot of Ladies stop me to ask me about my Maverick. That's a new on for Me.
JohnVena
Folly Beach , SC
Maverick 22
Deep sleep mode solution!!
I have a 2022 First Edition picked up on Oct 2022. It has been flawless. 2 days ago it went into deep sleep mode. I tried a long drive in sport mode with ac off and all accessories off. It still goes into sleep deep mode. Last night I searched the Maverick Truck Club postings and found this solution from FORD! I will take it to the dealer today.
@Senior Master Ford Guy
May 4, 2023
There has been some mention posted on here about 12 volt( low voltage system) battery drain and " deep sleep" messages from Ford Pass in Mavericks, today Ford released on the Professional Technician System accessible by Ford technicians this special service message, this may be something to have your dealer check if you are experiencing the problem of no start or dead/low battery. It does not specify that the mega fuse is being " blown" or popped, from my experience as a technician with some of the other models I have seen this mega fuse actually develop a crack ( typically caused by road shock/vibration)which can intermittently allow the loss of electrical charge to the battery, I've had them where they test good with an ohm/continuity meter laying on a bench but then with a little pressure applied to each end will test open. Ford does listen and research complaints/concerns with their vehicles and typically will give us( technicians) a heads up once they find a repetitive cause. Here is the service message, hope it helps some of you!
May 4 2023 New SSM 51598 2020-2023 Escape/Corsair, 2022-2023 Maverick – FHEV/PHEV - 12V Battery Voltage Low Or Discharged With DTC U3003:62 Stored In The DC/DC
Some 2020-2023 Escape/Corsair equipped with 2.5L engine full hybrid electric vehicle (FHEV) and plug-in hybrid electric vehicle (PHEV) powertrain and 2022-2023 Maverick vehicles equipped with 2.5L engine FHEV powertrain may exhibit a condition where the 12V battery voltage is low or discharged with diagnostic trouble code (DTC) U3003:62 stored in the direct current/direct current converter control module (DC/DC). The vehicle may also exhibit DTC U3003:16 and/or U3000:04 stored in the DC/DC module. This may be due to an open in the 300 amp mega fuse located in the high current battery junction box (BJB). To correct this condition, refer to Workshop Manual (WSM), Section 414-05>Pinpoint Test H1 to verify the 300amp mega fuse condition, replace the fuse upon confirmation it is open. Test and recharge the 12v battery.
Benson
Benson
Maverick Hybrid XLT
Ha! Use to be a $110 option. I'm assuming that's across all models?
My 2022 Hybrid XLT came with a keypad at no separate cost. Did they discontinue on '23 models? Wasn't aware of this until reading on this MTC site.
BluegrassNbass
Clif
Washington
2023 XL Hybrid
So anyways...I added this thing to my order. Can I place it anywhere on the truck or does it have to be by the door? Figured I would now add to this mass page post.
fordvideoguy
fordvideoguy
Salina, KS
I believe when you order it from the factory as a Dealer Installed Option it will be place on your door. If you get the one through Ford Accessories you can put it wherever you want.
BluegrassNbass
Clif
Washington
2023 XL Hybrid
Thanks, for the info. I will ask my dealer to stick it somewhere else if they can once they recieve it.
BluegrassNbass
Clif
Washington
2023 XL Hybrid
Either in truck bed or on the back tailgate.
Xbbqpitmaster
Full Time Gypsy
2024 Ford Maverick XLT
My '23 Lariat Hybrid came with 2 Key fobs. do some models Not?
For awhile they did not. But, the XLT Hybrid we ordered and just picked up on July 31 did have both key fobs.
Last Truck Ever
2023 Hybrid Maverick XLT
When I picked up my truck this week the salesman was showing me how to use the code, add my own, and I told him not to bother, I'd never use it. Got home, set it up, and I'm using it all the damn time now! Geeze, I was totally wrong, it's a handy little tool.
scotty
pompano berach fl
dodge caravan
The community has spoken and Ford has listened. Keypad is now a Dealer Installed Option, cost is $230 and can be added to the order now.
I ordered a xlt 2023 back september 2022. I finally got email from ford saying
they will start my build week of september 2023; it says my truck includes the keypad.
I don't understand. Why are you saying it is an option? Do you mean 2024 trucks?
