Retrofit Adaptive Cruise 2025 XLT
84convertablegt
Aaron
Ohio
2025 Maverick XLT AWD Hybrid
Ford doesn't make it easy anymore.
HaveMave
Alex
Houston
2025 XL
Alot IPMA blocks are not available for me to update. Any block with number 3 and on are not in the car( crossed out in my markups). I didnot want to update half. I took the notes on old sheet what I found different. Anyone with 2025 maverick CCM could share some of these numbers from their modules? If you know that one which bring in CCM to show in module let me know. I can randomly try some but again worried that will brick my car.
Ford Maverick Retrofit Adaptive Cruise 2025 XLT image
BlueSpec1
Gene
Does your IPMA have 706-02-02 ?
That's where F150 IPMAs enabled CCM.
inline_five
2023 Hybrid XLT
You need to compare lariat hybrids with adaptive cruise and lane centering installed to yours and then go line by line to determine what the change is.
There is a nice program that lets you compare module by module here:
https://www.compulsivecode.com/Project_AsBuiltCompare.aspx
The 22-24 seem to be completely different in terms of how they are set up.
rusty_shackleford
Dale
texas
2025 XL
So we need a kind 2025 lariat owner to share their as built files, any takers?
rusty_shackleford
Dale
texas
2025 XL
You can always just find a Lariat vin number in the for sale ads online and then download the as built file here
https://www.motorcraftservice.com/AsBuilt
It will open in FORSCAN when you click load all in the module you want to see
Thanks, got some info and made a sheet to compare with my VIN and a Lariat for sale nearby.
I see differences between my truck and the notes @HaveMave took as well, probably due to differing options between our XLs
The IPMA is so different from the 2024, I decided to included them all, just gotta figure out whats what.
My scan tool will be in tomorrow and I can compare the as built with whats on the truck too.
Edit: tagged the wrong person sorry!
Ford Maverick Retrofit Adaptive Cruise 2025 XLT Screenshot 2025-06-14 193726
Ford Maverick Retrofit Adaptive Cruise 2025 XLT Screenshot 2025-06-14 193816
Ford Maverick Retrofit Adaptive Cruise 2025 XLT Screenshot 2025-06-14 193854
BlueSpec1
Gene
Ford Maverick Retrofit Adaptive Cruise 2025 XLT 1749951117773-s1
This compare: 02-02 XL to Lariat appears to go x04x to x05x as the F150's do.
HaveMave
Alex
Houston
2025 XL
I did not check this but there was activate adaptive cruise control in EZ menu. That didn’t do anything. I will try this later.
HaveMave
Alex
Houston
2025 XL
Surprisingly my backed up Asbuilt before I do anything and I downloaded from motorcraft service is different. I did not see any difference it made but some code gets updated. I assume same for Lariat.
HaveMave
Alex
Houston
2025 XL
At this point I ran out of options. On touch my CCM module is warm-hot. There are some menu in EZ side of forscan in IPMA. I could enable ACC like set radar to present and fusion radar like that. When tweaked those, I got a message like lost communication with CCM?( Didn’t take pictures, talking off memory) U0104 code -and U2101 incomplete or incorrect input but nothing much
I reset back everything. Right now I have a code U??? for calibration of camera in IPMA which I believe will go away once I hit the road with nice markings.
zorki1c
Wayne
Boise Idaho
1994 Maverick Lariat
it's true that it's possible to option an XLT so much that it gets uncomfortably close to lariat pricing.
however, I thought about doing this retrofit on a no-options Lobo 402A because I don't want the sunroof or pleather seats in the 702A, and it's 5.5k cheaper for the 402A ($36500 vs $43000, roughly).
I further thought about buying a Tremor grille to mount the ACC radar problem-free, but that would bring the ACC add-on into the 2k range.
Should have got a Lariat
Carlitos_92
rusty_shackleford
Dale
texas
2025 XL
I scanned as a new profile but I didn’t change anything in IPMA yet, if that’s the case I will try again when it is a little cooler outside.
Adding pin was hard part. There was no pin in 9, 18, 19 and 20. I added and checked with multimeter for continuity.
where did you find the extra pins for this plug? I want to take a crack at this and see if I can get the CCM recognized.
Did you ever get the missing blocks to show up earlier?
That happened to me today messing with the ACM. Wrote changes to 7D0-01-01 and power cycled the truck, got a DTC and block 01 was absent. I reset the DTCs then tried to connect to that module again, and the missing blocks came back, reverted my changes and all was well again.
HaveMave
Alex
Houston
2025 XL
I had pins available for another make shift pigtail. I put those in the IPMA pigtail at 9 18 19 20. CCM never got recognized. I think either those pin number were not correct or my CCM had gone bad. I had connected everything temporarily so after that I reverted connection to the factory config. I still have camera calibration DTC. It didn’t go away even I drove a while. I do not see calibration service in forscan. If any of you know how to calibrate camera in Forscan please let me know.
