Ozarkbeard
WOW. Thank You!
I've been wanting to disable the GD panic button since I took delivery of this truck and set it off the first evening the truck was in the garage.
One question, though. What did you use to remove the button off the board?
MO1
MO1
Aaron
Utah
2024 Xl AWD Mav
WOW. Thank You!
It popped off with my pocket knife
Ozarkbeard
BoboysTruck
Virginia
F150, Focus, Juke
I just popped the button out and taped it up to keep the dirt out.
Ford Maverick Remove panic button from Maverick key fob (DIY how-to disassemble) 20241108_164857
commadorebob
Is it something with that specific keyfob? I have the Lariat with keyless entry and have my fob in a case, but I have never found the panic button to be easy to push by accident (or intentionally for that matter).
Toddman45
St. Louis, MO
Why would you remove the button? That is how you find your car in a large parking lot. Hit the panic button.
Probably the same reason you'd put a cargo net on your lariat's front door panels with self tapping screws running through the plastic door panel.🙄😆🫣🫣
Ford Maverick Remove panic button from Maverick key fob (DIY how-to disassemble) Door net
MO1
MO1
Aaron
Utah
2024 Xl AWD Mav
I have no need for panic button so I removed it & will never have the accidental panic push. Takes 5 mins to disassemble fob & remove button. Everyone has different wants & needs. I just wanted to share with the community because I use forums for all sorts of shit to gain knowledge & different ideas/viewpoints. It's amazing to get ideas from soo many different people. That's what makes the interwebs soo great!!
Ozarkbeard
Baring the laptop that is still potentially cheaper than having to program a new fob because ya goofed removing a button.
Programming a new key fob is free. You can do it yourself. It takes only a couple of minutes. Cutting the key itself can be done by a competent locksmith. It cost me $75 to have the two metal keys cut.
