Ozarkbeard
I have no need for panic button so I removed it & will never have the accidental panic push. Takes 5 mins to disassemble fob & remove button. Everyone has different wants & needs...
This. I do not use it and never will. Have no need for it. I have also accidentally set it off several times at places that were really inappropriate to be honking a gd horn. The last time it accidentally was triggered, I could not get it to stop with the fob. The fob will not even unlock The driver's door, so I had to use the metal key to get that open. Then I had to put the key in the ignition and start the truck to get the stupid panic alarm to shut off. What a crock!
Thanks again, MO1, for posting this very helpful information, and with excellent step by step photos.
  • Like
Reactions: MO1
lajlmt
Lance
Rio Rancho
‘23 Maverick XLT LUX
MO1
MO1
Aaron
Utah
2024 Xl AWD Mav
Great! But, I need it to find it at mall😂
No one should be going to the mall...😎 I haven't been since I was a kid to go Spencer's & look at all the weird shit & of course the posters in the back with the cute gals in seductive outfits that have always been waay outta my league🤣🤣🤘
Mr Pibb
Vegas
2024 Lariat
Programming a new key fob is free. You can do it yourself. It takes only a couple of minutes. Cutting the key itself can be done by a competent locksmith. It cost me $75 to have the two metal keys cut.
Yeah but if you screw up one of your keys your sol on programming your new one for free unless you already had one made before.
WOW. Thank You!
I've been wanting to disable the GD panic button since I took delivery of this truck and set it off the first evening the truck was in the garage.
One question, though. What did you use to remove the button off the board?
I just have my panic set to require two button pushes to activate
Why would you remove the button? That is how you find your car in a large parking lot. Hit the panic button.
I just hit the lock button twice and the lights flash and horn honks once if lock is successful or twice if lock is not successful.
Charles T.
Charles T.
Metro Atlanta
2017 Edge. 2025 Maverick Lariat
Is it something with that specific keyfob? I have the Lariat with keyless entry and have my fob in a case, but I have never found the panic button to be easy to push by accident (or intentionally for that matter).
agree
Ozarkbeard
TruDat.
I have enough spares atm. If I need any more in the future, I'll get the stealership to program another one.
lajlmt
Lance
Rio Rancho
Dad
Probably the same reason you'd put a cargo net on your lariat's front door panels with self tapping screws running through the plastic door panel.🙄😆🫣🫣
I truly fail to see the analogy, but perhaps others do.
Dad
Not sure why one would want to do this. Yeah, I've accidentally set off the panic button maybe 3 times in the 2 years I've had the truck, but seems to me the advantage of having a method to scare off intruders, attract attention in an emergency, or merely finding your vehicle, far outweigh the problem of accidentally setting it off.
Ozarkbeard
There are reasons why. Here's one that happened to me twice:
Try setting it off accidentally when you're parked right by someone's bedroom where they are sleeping, only to find the GD thing won't shut off until you: Manually unlock the door, put the key in the ignition and turn on the truck. This happened to me twice. And I do not want it to happen again. I don't need the stupid panic button. And when I park my truck in a parking lot, I note where it is, so I won't annoy people by rudely setting off an annoying alarm, just to find my truck later.
To OP: thanks again for posting this very helpful information!
BoboysTruck
Virginia
F150, Focus, Juke
Mine was accidentally setting it off before sunrise getting ready to go into the woods to hunt. Property owner didn't say anything but I'm sure they weren't happy. I wasn't gonna wait until they said something.
Button came off after the second time it happened.
Carlitos_92
A lot of people with Hulk hands or something around here I guess. 🤷‍♂️
