Remote Features Disabled To Preserve Battery Life.
I periodically get this same message with my '21 Ranger XLT (40K Miles). I've had the battery checked a few times when getting my tires rotated and it's always come up fine. My Auto Stop/Start function also only seems to work sporadically for no apparent reason. I wonder if these things may be related to the same issue in both models?
Manual for EB, likely the same for Ranger, points out the auto-start/stop won't work if battery is felt to be a problem, ie low voltage.
Needs to conserve enough battery for your manual turn-off and next turn-on.
Brumbach
2009 Ranger xlt
*****UPDATE*****
Just picked up my Maverick. Results as follows:
#1-Dash rattle was verified and TSB 24-2317 was installed.
#2 Water coming into passenger floor at glove box verified. HVAC air inlet screen seal deformed. Replace #18D395 inlet screen and dried carpets.
#3 Battery saver mode on. Battery failure #10655. installed GRX tester and failed. DTC code 5U7 R4JX aces code F86ER. Replace battery and reset BMS. Part# BXT*99RT4*A
***Try to talk to the guy working on the vehicle if you can. A service advisor is a sales position and may not have a working knowledge of what was done or what was wrong. ***
DougK
Doug
Denver CO
Maverick XL hybrid 2024, Honda Fit 2009, MDX 2006
https://www.nhtsa.gov/?nhtsaId=11009437
Not a recall but close. Challenge will be getting your dealer to acknowledge and do whatever Ford will come up with.
To me it's not "some" but almost all.
thank you, good to have the nhtsa id.
My 2024 has not yet displayed this behaviour.. driving it only every 2nd or 3rd day, still have my Sport Trac so alternating between them.
tccontender
Geno
2024 Maverick XLT
Changing to an AGM battery really does nothing unless you want to change the position ie lay it on its side, assuming comparable CCA specs. Perhaps a solution is a bigger battery. I had similar problems with a CRV and the biggest battery I could stuff in the hole cured it. That's what I am going to do.
Six Toed Slim
Peter
Minnesota
2010 Toyota FJ, 2008 Ford Focus, 2025 Maverick Hybrid
Keep reading, a major point is being missed in the mix.
Deep sleep is done if truck sits too long without being driven, or voltage drops below a point.
The sole reason for that is so there is enough juice left to start the vehicle.
So you don't come back from a long trip to dead battery.
You'll find those posts too where it worked exactly like it was supposed to - truck started up.
You'll notice the number with drained batteries like your mom is NOT the issue brought up very often at all.
The truck going into battery saving mode slowly, or deep sleep mode finally - is the issue.
Many of the cars today with advanced remote access functions or keyless entry do something similar to cut down on battery usage in order to start the vehicle after some time undriven.
Thanks for helping clarify this. I hesitate with forums most of the time because people seem very irrational at times (this $600 rifle is garbage because it doesn't perform as well as my $6000 rifle, etc). I am just trying to make an informed decision before plunking down 40K to replace my old focus as a back and forth to the airport parking lot. And the reason I am going all out is that I need something that can carry kids hockey gear and also get ok milage and also fit in a suburban garage.
Mark1
2024 Maverick XLT
All that he said is true. But and a Big but, there is more to this constant sleep mode having to do with a intermittent parasitic voltage draw as stated in the SSM. Toyota and Honda Hybrids have never had this problem. Prius has been around for years. If you need to drive a car around to charge the 12 volt battery all the time so you have access to the vehicle accessories something is not right. If you need to constantly trickle charge when the vehicle sits for a day or 2 in fear of battery sulfation and dieing over time, somethings not right. If you accept this and the vehicle goes out of warranty and you possibly have to buy batteries all the time, let it be.
Mediocrecy seems to be ok for some.
Yes I never got any deep sleep problem with my 2012 Honda crv because Honda never told me. The larger battery than the one in the maverick would just die every 24-30 months. It was the charging logic. The car also did not have as much key off battery activity either. My 4th battery was on month 61 when I got rid of it because I was putting my noco g5 on the battery for 5-6 days every 3-4 months. One solution for maverick would be installing a second 12v with automatic controls to switch batteries every 4-6 weeks to allow the idle battery to be properly trickle charged to 100% and kept there and desulfated, etc. This would be an answer for those who wish to not be bothered with messing with maintainer. I will continue to use maintainer until I see the Ford Fix coming soon.
23grayXLT84
Midwest
23 hybrid xlt
Type in Ford (model name of your choosing) battery saver mode. It's really a (shitty) feature that Ford is know for and unfortunately mavericks got the short end of the stick on that one.
Make a feature, but don't make it inconvenient for the end user. Having the dome lights turn off is the dumbest idea ever.
No dome lights is definitely not what I would have chosen over a big red battery flashing on dash or similar, but an early warning is necessary and appreciated. I would prefer a resting battery voltage display taken before anything else was fired up.
*****UPDATE*****
Bummer a seal was put on badly, glad it appears easier fix than some other reasons.
So a bad battery.
Yep, quality seems suspect on many posts like this.
Charging logic doesn't help.
At least you didn't have a drain killing it every night. Well, that actually would cause a troubleshooting session probably. Still.
Brumbach
2009 Ranger xlt
So a bad battery.
I turned off all the wifi/ connect , app crap in the infotainment screen too when I got home. I won't get alerts but I can tell if it's happening by some lights not working . Dash sounds much better so far. Hopefully the waterfall is shut off too.
Might reread that SSM. The word used is always Drain.
Intermittent drain.
Wake up, go to start truck, battery is dead.
Your prior days were just fine.
https://dot.report/bulletins/11009437
Some 2022-2024 Maverick vehicles equipped with 2.5L full hybrid electric vehicle (FHEV) powertrain may experience an intermittent 12V battery drain condition when the ignition is turned off. If the 12V battery drains, perform a 12V power reset to the vehicle by disconnecting the 12V battery negative cable for 5 minutes. Fully charge the 12V battery and use the Rotunda GRX-3590 or DCA-8000 tester to determine if replacement is needed. If replacement is needed, fully charge the new battery and perform a battery monitor sensor (BMS) reset. Engineering is currently working on a software solution for this condition that is expected in the first quarter of 2025.
Contrast that one with this one which is about a parasitic draw.
They use specific words for specific cases which mean specific things.
https://static.nhtsa.gov/odi/tsbs/2024/MC-10250522-0001.pdf
Some 2021-2024 Bronco vehicles may exhibit a parasitic battery draw. This may be due to an interior door lock switch on the driver's and passenger's interior door panels. Prior to normal Workshop Manual (WSM) diagnostics, check both front door lock control switches for damage and/or proper operation. If a front door lock control switch does not operate as designed, repair as necessary. If no problems are found, continue with normal WSM diagnostics. For claiming, use causal part 14028 and applicable labor operations in Section 10 of the Service Labor Time Standards (SLTS) Manual. If the draw is still present, refer to WSM Section 414-00 for normal diagnostics.
You might also educate yourself beyond your own experience if this is effecting other vehicles. Never say Never!
https://topclassactions.com/lawsuit...action-claims-defect-causes-draining-battery/
https://normantaylor.com/blog/class-action-lawsuit-filed-over-drained-honda-battery/
Also notice in those the different effects between parasitic draws and the Drain in the SMS you keep referencing.
23grayXLT84
Midwest
23 hybrid xlt
Intermittent drain.
Did you notice in the notice to disconnect negative cable for 5 minutes. I bet that though a temporary solution resets some modules to reduce that draw
It is a complete power cycle.
Which all know is useful for computers.
Can't hurt!
Probably confirms that reboot on whatever module was causing the drain.
So they don't recharge battery hooked up, and it just happens again.
Shoot, even Forscan Lite has procedures for doing that to individual modules.
For instance.
Ford Maverick Remote Features Disabled To Preserve Battery Life. Screenshot_2024-12-13-15-03-33
Mark1
2024 Maverick XLT
Intermittent drain.
We keep parsing words here. It is a drain from the modules. Do you work for Ford. You keep defending them and giving alternate battery survival techniques. That's fine for an interim fix but not a solution to abate, mask or cure the problem. Well I'm done on this issue and making people aware that it is more than just driving habits, charging responsibilities and being the vehicles human computer.
Peace out!
