Recomendations for snow capable tires
F150 2.7 TT user
Kenneth
SE WI
2026 Maverick Tremor, 2017 F150 XL 2.7
Have used Vredestein, Blizzak, Hankook iPike, winter tires in the past. The Nokian Hakkapeliitta LT2 were the best winter tires I have used. Live and drive in WI.
usedtobef150
canada
lobo
Optimus
MN
2023 XLT Hybrid
For pure safety purposes, I run dedicated (nonstudded) snow tires in the winter. Nokian Hakkapeliitta or Bridgestone Blizzaks are my top favorites for northern MN winters. Used them both on different vehicles, plus lots of other brands of “proper snow tires” over the years that I didn’t like as much. If I had to pick between these 2, I’d go Nokian.
Finlanders know snow!
Personally I don't like the mostly straight siping on the Outpost APT versus a zig-zag sipe for more bite into ice if one wanted to use it as an "all-weather AT".
Consequently when the Rotiivas on our work plow truck needed replacing (another downside of the Nokians is they get considerable dry rot at 6 years) I ordered a set of Vredestein Pinzas and those got good marks from the operators. Although I don't know if I would recommend the Pinzas for a Hybrid Maverick as they're somewhat on the heavy side.
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
Get a set of steelies if you live in an area where they use salt. Salt eats aluminum rims really well. If you have any ice then you need Blizzaks or X-ice or equivalent tires that are made of super soft rubber and super compliant sidewalls and micro-siping. Don't get blocky AT tires, as they have a smaller contact patch and will give less traction unless you are in deep snow. They look cool, but suck.
Tbone91
Fulton, NY
2024 Ford Maverick XLT FX4, 1991 Chevrolet Camaro RS
I went with Pirelli Scorpion Winter tires. Seemed to work pretty well for our upsate NY winter. There were a couple guys at work with "real" trucks (according to them lol) that found out real quick that true AT tires don't do shit in real snow....no matter what kind of "manly" truck they think they have 😆 to each their own tho
F150 2.7 TT user
Kenneth
SE WI
Ford Maverick Recomendations for snow capable tires PA170006
These are the Hakkapeliitta LT2s I used on my 2wd F150.
Ford Maverick Recomendations for snow capable tires P2100035
Groo
UP of MI
26 XLT
the Michelins do look like good tires. might give them a shotbor their Goodyear cousins.
I seriously wonder about you guys claiming ATs are worthless in snow. When my wife was doing home healthcare we got ATs for her FWD minivan. It made a huge difference. Snow gets trapped in those spaces between the block and that snow stick to ice far better than rubber does.
They might not be quite as good as pure winter tires, but they last drastically longer.
1929
Lake Michigan
Ford Maverick XLT Hybrid
I like Kumho Crugen HT51. Highway oriented, snow rated tire. I call it the poor mans Michelin.
Rick65
Rick
So Cal
2024 FX4, 4K tow
Nokian Outpost APT is a great tire for snow. Also they are low rolling resistance so great for a hybrid where you don’t want to hurt your mpg.
Tbone91
Fulton, NY
Personally never tried AT tires as this is my first truck and I just went with the 3 snowflake winter tires. I usually do snows on my sedans I had so just kept the same pace for my Maverick. I don't have a need for AT tires...at this time anyways. All I know is 3 of my coworkers had ATs of some sort, one on a Silverado 1500, one on a GMC 2500 and one on a mid 90s Cherokee and all 3 immediately ordered snow tires after some serious snow fall. Maybe the drivers, maybe the vehicles, maybe the tires 🤷‍♂️ maybe all 3 😄 not really sure but none of them were pleased in the snow.
Optimus
MN
2023 XLT Hybrid
What I like about dedicated winter tires is that all the extra siping collects sand and grit. Combine that with these top brands of tires that add silica right into the rubber, and they get even more grip (think sandpaper). That, and the rubber is much softer. But this means they wear faster and are no good for summer use.
If you are in the UP and are measuring snow by the 100 inches, I would seriously consider true snows. The ice grip alone is worth it, as is helping to avoid accidents/injuries/deductibles.
Timothyd
Yes, true snows just during winter are the way to go. I got Blizzaks from Discount Tire and they swap the wheels twice a year for free.
Cancunbadlands
Cancun
Cancun
Yokohama
