Rain Water in Driver's Side Floorboard
HybridMavGal
Eskimo
2025 Hybrid Maverick Lariat, AWD, 4K Tow Package
Night before last we had a nearly 2" rain; the next morning there was at least 2 inches of standing water on the floorboard. I drove straight to the dealership and they checked all the drains, said there was "some" tree debris and that may have been what caused the overflow into the cab. Has anyone else experienced this? The rest of the cab is completely dry, including the ceiling.
Ford Maverick Rain Water in Driver's Side Floorboard IMG_0801
Well, that sucks.😲
You may want to consider a product such as this.👇
Ford Maverick Rain Water in Driver's Side Floorboard 20260507_093619
Supposedly it stops the leaves from getting down into the drainage channels🤷‍♂️ I cannot vouch for it I don't own them I'm just passing on information and the Maverick truck Club thread from other members.
Ford Maverick Rain Water in Driver's Side Floorboard 20260507_093604
https://www.mavericktruckclub.com/forum/threads/🌧-stop-leaves-debris-protect-your-maverick-with-hood-water-barriers.70946/
If you are into 3D printing or know someone who is here is another option.
https://www.mavericktruckclub.com/forum/threads/baskets-to-keep-leaves-out-of-your-engine-bay.73979/
I truly hope that one of these products is a solution to your problem. Please keep us updated. Good Luck
GB
There’s been numerous post, usually the plastic cowling under the windshield
bgn
WA
Your dealer told you to pound sand nicely.
It's likely the air inlet cover like has been mentioned.
That's on the drive's side too?
thats a lot of water. be sure to remove your floor liners and verify the none of the carpet, driver & passenger side got soaked. Prime place for mold to grow and stink :eek: you may want to search the forum for the term water leak and see the various resolutions
HybridMavGal
HybridMavGal
Eskimo
Thanks everyone for all the input and help - I took it back to dealership today so they can pull carpeting/mats and to put in front of industrial fans overnight. I mentioned the above things to look for as well - so much appreciated. I am also purchasing the Maxzina Hood Water barrier mentioned here. I will update after the next big rain!
Sounds like a plan.👍
Good Luck,
GB
MotoWojo
Madison, WI
2025 Hybrid Maverick Lariat w/4K Tow Package, 2016 Ford C-Max Hybrid
I heard more than a few stories about water on the passenger side, but this is the first time I've heard of a water problem on the drivers side. Here is a good Youtube video covering water on the passenger side:
jimbabwe
Virginia
20205 Maverick XL AWD Hybrid
I bought some knockoff water barriers from Amazon for $15.99 and installed them months ago. So I didn't have a problem in the first place and will never really know if they prevented it, but I sure don't have an accumulation of leaves and other debris that was happening before I put them in. They are pretty light/flimsy feeling, but have done the job and survived snowy, icy winter. I warmed them and did some slight plastic bending by hand th ensure best fit.
Well, that sucks.😲
GB
I am totally forgetting to check those when checking oil at fillups.
Or nothing is in them to catch my eye.
I'd actually think this could cause a problem though if not watchful, because the water route from there just pours down the edge behind the fender.
If you forget to keep the area clean, seems like water could back up all around the cowling making a situation worse, if you had a potentially leaky spot.
I'll have to look at height differences better, maybe it runs over anyway if you allow it to dam up.
Those debris barriers also help leaves from building up at the bottom of the fenders where the water is supposed to drain. At least according to this picture published by the 3D printed basket thread.
Ford Maverick Rain Water in Driver's Side Floorboard 20260508_114237
HybridMavGal
HybridMavGal
Eskimo
UPDATE 6-8-26: We had another couple days of very heavy rain and yes, another massive overflow into the entire cab (7 inches of rain in two days). The dealership kept it for 6 days, pulling all the seats, the headliner, all the carpets/mats - they did a great job isolating where and how this is happening. An A.R.E. canopy was installed in March 2026. Both water intrusions happened after this. The installer foot the bill on this one, as it was installed too close to the back of the truck cab, and the water could not escape fast enough out the sides. It was became a pool back there and it all went through the back window. That meant water behind the back seat, under the back seat and in the battery well there, in the ceiling and down the back columns, the front of the cab as well. Any sort of tree debris that was stuck between the canopy and cab also seems to have contributed to the problem. The canopy installer adjusted the canopy back 1/16" of an inch and 7 hours of water testing was completed without issues. Just to be safe on any tree debris (I park outside) in the future, I am now blocking the top spacing between the canopy/cab with a few simple foam backer layers that are zip tied together. The truck has no mold/mildew smells thankfully, the dealership did a great job preventing this from happening. The maverick being a uni-body truck contributes to water escapement concerns, IMO. Hope this helps someone!
