801Maverick801
Utah
Subaru Forester
Installed a motor for the Manual Rear sliding window in my 2022 XLT. Wanted to use the OEM Switch as well. Was a fun project, quite the investigative project trying to find the right connectors for Everything.
-Purchased a Motor assembly with cables from a Lariat wreck for 150$
Mounted motor with Rivnut Inserts at existing location. Added 2 standalone 5 pin relays below the motor (also with Rivnuts) to stay with the schematic. I already have ran 0 gage wire for my Inverter behind the backseat so I stole power for the load side of the relays from there.
Purchased a switch bezel from a wrecked Lariat on ebay, found the correct 6 pin molex connector on mouser to interface with the rear sliding motor switch. Ran 2 twisted pair from the switch, Pin One power input (spliced into White/Blue wire out of Pin 2 on the C22BOF connector of the BCM) to stay with OEM schematic and wired a ground to pin 6 of the molex to provide ground for the backlit switch LED. Pins 2 and 3 was a twisted pair ran to the control side of the standalone relays in the back.
The Lariat Bezel had the push to start switch port, I used that space and added a 12 Volt Accesory plug.
Ford Maverick Power Rear Sliding Window (OEM-ish) on 2022 XLT -- DIY Installed 20260724_120259
Ford Maverick Power Rear Sliding Window (OEM-ish) on 2022 XLT -- DIY Installed 20260722_204710
Ford Maverick Power Rear Sliding Window (OEM-ish) on 2022 XLT -- DIY Installed 20260724_110747
Ford Maverick Power Rear Sliding Window (OEM-ish) on 2022 XLT -- DIY Installed 20260723_112305
MavStangVa
Here, There, and Everywhere
2024 LARIAT AWD
Nice job, and great write up. I do have a question. Do you have to use the Taco Bell sauce to lubricate the wires to pull them through? Or is it just to spice up the installation? 🤣
710
MICHIGAN
2022 FX4
Thanks for the roadmap! I’ve been wanting to do this! Might be the only option not on the truck that I wanted!
801Maverick801
Utah
Subaru Forester
If you know how to crimp and deal with molex pins/connectors I can get you some Part #s! The Ford Pigtail kits are an absolute rip-off
CarbonGrayFX4
Luke
Virginia
2024 Carbon Gray XLT FX4
Nice job! I have been contemplating replacing my non-slider with a salvaged auto slider. Is the manual slider frame identical to the auto? How did you attach the regulator to the actual window?
801Maverick801
Utah
Subaru Forester
Yes, the manual slider has the hook ups for the cables, you just need the motor with the cables.
710
MICHIGAN
2022 FX4
Please, list them for us all.
I see you did the same thing I keep thinking of doing when I’m driving but forget when I park and get out because that’s all I’m thinking about is getting out of the truck😆 removing the rear headrests when not in use for better rear visibility!🫡
801Maverick801
Utah
Subaru Forester
Okay so if you want to use the original switch from a Lariat you will need this connector and pins from Mouser
6 pin molex
Here are the pins, they are cheap, buy 10 of them
Female molex pins
I was hesistant to post the connector for the motor becuase there is some different iterations of it. Dont buy the connector til you have the motor in hand, if possible ask the wreck yard for the pigtail if they will do it.
If this is what your motor connector looks like, this is the connector/pins you will need.
Motor connector
Pins for motor
Ford Maverick Power Rear Sliding Window (OEM-ish) on 2022 XLT -- DIY Installed 20260708_221848
Cancunbadlands
Cancun
Cancun
Nice job, and great write up!
Surly Old Bill
bill
Richmond, CA
2024 Maverick XL
keeps the squirrels from chewing on the wiring...
Marty
2026 Ford Maverick Tremor
Outstanding work,
Makes me very glad my Tremor came with the sliding rear window, Cost was $350
Jroberts302s
Josh
Nashville, Tn
2023 maverick,2012,fusion, 2014 focus,2003 cobra
I tossed those the day I bought my truck 🤣 my salesman is a close friend & has a Maverick also I grabbed them & said you want these before I trash them 🤣
