LXT Now with power REAR window under 100.00
Bodageta
RICHARD
Georgia
1995 Chevrolet K1500, 1989 Corvette Conv
Same. Any updates or additional pictures and maybe part numbers would be greatly appreciated. One concern I had was the potential that larger trucks had more travel than the Maverick. Also, is it possible to swap only the center glass to a non latching glass
Automan21
Mel
CT
ā€˜23 XLT Eco AWD 4K Tow
I was thinking the exact same thing. As far as the non latching I would just take the pin out of the existing one. Never know when you would have to swap back if the motor burns out or jams
Earl313
Earl
Grosse Pointe Park Mi
BMWZ3 Ford Fusion Nissan Altima On order xlt lux
Here are a couple of pics on install. Mounting of switch is temporary but not urgent to run to new location. I just reach down and activate.
switch is 6 pin rocker, motor stops on release, direction using rocker. The F150 motor sorry don’t have number, but I bought ā€usedā€ on Amazon.
i just removed the latch from sliding window Cables secure the slider.
cables on the motor are spring loaded, make sure the stay taunt. 2 cable are different length I used shorter cable as is, longer cable was cut along with the sleeve. I soldered the wire before cutting to stop fraying . I used universal xtra small cable end…from throttle kit to use on cable end going into slider window frame.
motor is behind the seat so scrap plywood was wedge in the vacant OEM mount….it works!
switch in held by gorilla tape, again was temporary, but not on top 10 list of things to do.
this setup has worked all summer it is proven to work.
Ford Maverick LXT Now with power REAR window under 100.00 IMG_0148
Ford Maverick LXT Now with power REAR window under 100.00 IMG_0145
Bodageta
RICHARD
Georgia
Many Thanks for the details
The Cyber Orange Guy.
Devu
Caribean
Maverick cyber orange
Hey thanks for the info,
If you ever have the time and make a video for youtube it gonna be more than apreciated.
Thanks in advance.
Bodageta
RICHARD
Georgia
I’m watching this thread.
