LXT rear window change to power controlled?
Earl313
Earl
Grosse Pointe Park Mi
BMWZ3 Ford Fusion Nissan Altima On order xlt lux
I am in the first few days owning my 2023 maverick. Love it. I have installed oem hood protector, redneck garage DRL and a X Cover trifold cover. Would like to have remote control over the rear cab window. Has anyone done this or have ideas how to make this happen.
Ellebob
bob
Western Ma
Mazda 5
I would like that too if there is an aftermarket solution. I just got my Maverick a week ago and I am really enjoying using the sunroof with back window open. Would be nice to be able to open the rear window on the fly.
TheShark
Pity us '24 owners, I'm sure we would love to have any rear window, manual or otherwise.
Earl313
Earl
Could a lariat owner post a pic of the rear power window. Hoping I need no major mods to do this and pic of window may give ideas.
TheShark
I had a rear power window in my '22 First Edition and it looks completely different than the manual. You'd probably have to buy an entire window not to mention adding wiring and a switch.
Phileaux
Frank
New Orleans, La
2010 Ford Edge SEL fwd
There is a worm gear in the bottom of window and cable leading to motor. There are pics here when people show behind back seat. If it happens definitely wright it up and share please.
Earl313
Earl
Looking for totaled lariat in local salvage yards this week. Will check ford oem parts for new cost. Wiring should not be a problem. research makes it sound worm gear,window and motor sold in a package.
otroad
NY
2023 Ford Maverick XLT Hybrid Lux package & 360 cp
Aftermarket solution is use Dorman motor and cable asy P/N 777-300 readily available on multi sellers Amazon , Walmart .com etc Just be careful what switch u use must be a 6 or7 prong rocker also readily available. Dorman motor asy is not the best quality of design as it utilizes steel cables on a plastic spool. Motor will not reverse itself , so again correct switch usage i s critical I used this setup and it works ( I cannot post pics) I found out the Hardway about polarity reversing motors and switches! . Hope this helps has overall this mod will cost less then $100.00 vs Ford wanting $1016.00 for parts alone!. Rear sliding window IMHO is almost useless with out power.
Earl313
Earl
Did the same conversion of my. Manual xlt rear window
ndmiller
Noah
Atlanta
2024 Maverick XLT Azure Blue Metallic
Just went out to my Maverick, solid perm window, thought I was losing my mind. 24 XLT.
