Power Inverter location?
LC48
Johnson County Texas
Where did Ford mount the inverter, I don't have the factory installed unit but would like to poke around where the company normally mounts them to see if by chance the harness is in place.....
Any help appreciated!
Big_T
T
2022 Maverick XL Hybrid
Edited to remove incorrect information.
Ford Maverick Power Inverter location? rr
Mas280
That's not the inverter is it? I have that on my truck and no 110v outlets.
OldSoulNewMaverick
NW Chicago Burbs
2014 Kia Soul
The in-cab inverter is on the back of the middle console (armrest). Next to where the USB plugs for the rear seats are.
Big_T
T
LC48
LC48
Decayed
yes
a car
Ah, not sure that is correct. The OUTLET is on the rear console. The actual inverter may well be elsewhere. After all, if you get the lux pack and have the one in the bed, there isn't a second inverter there. The question is where do the wires from the outlet go?
thunaman
Andy
Peoria AZ
2017 Subaru Outback
I don’t know about the wire harness for the inverter, but I do know that there are no wires in my truck for the outlet in the bed. I would assume that to keep costs down there is no extra copper in the vehicle.
LC48
LC48
Just curious to find out, generally Ford & Toyota, and probably others, only lay in one "master" harness as a cost savings/efficiency of assembly deal.
I bought a dealer ordered truck and they did not spec the inverter. I have occasion to power up a laptop and office in my vehicle, so looking for the cleanest install options.
When I get the chance I will check out the center console area - one day the tech docs will catch up with consumer demand....
EMD_Driver
South Carolina
2015 F-350 DRW 6.7 / 2022 Maverick XLT 2.0 AWD
Has anyone verified the location of the actual inverter and not just the outlets?
Criss944
Criss
Horry County, SC
Silverodo
Just remove the cover in the bed on the driver's side. If their is inverter wiring it should be easy to find.
huunvubu
coppell tx
2023 Ford Maverick Hybrid
Picture #1 behind back seat of a Hybrid Maverick XLT with no 110V/400W Outlets
Picture #2 behind back seat of a EcoBoost Maverick Lariat with LUX package and has both 110V/400W Outlets
Picture #3 EcoBoost Maverick Lariat with LUX package showing Cab 110V/400W Outlet
Decayed
yes
a car
Second pic, what is the silver box with the cooling fins? Is that the inverter or the B&O amplifier? It's kind of big for a 400 watt inverter.
TacoHolder
Phoenix AZ
Not Mav
I wonder if it would be safe to replace the console USB fuse with a 10A or 15A and use a USB to barrel plug adapter to power your laptop. You don't actually need an inverter just to use an AC adapter to convert back to DC. AFAIK the rear console USB has a 5A fuse behind it and the front ports wire directly to the infotainment system.
EDIT: Not enough voltage. Probably won't work.
