Ok, who installed Weize H5 in their Hybrid? we need details!
mcluvin
CR-V
There are metal tabs under the original battery. You will need to either cut them off or flatten them down a little.
i didn’t notice the tabs when I installed mine. It seems to be sitting flat judging from my pics. Did anyone else flatten the tabs?
Chris_G
NOVA
C-6 Corvette
Yep
scotty
pompano berach fl
dodge caravan
So another model H5? Does it fit in the compartment without modification? - H5 appears to be the width, but roughly 1/2 inch taller, which I believe should fit, given my BT Battery Minder which is 1/2 thick is double side taped to the top of the factory battery. My concern is the 1-1.5 inch longer length, and whether it fits in the box. (I'd rather not cut up the plastic surround on a new truck).
Walmart also has an AGM with 4 year free replacement in size H5, along with a few others. That size gives a LOT greater reserve than the little H4/99R stock battery.
I just looked up the everstart walmart battery agm $180 bucks. it says length is 9 9/16.
Did you come up with a resolution for your battery choice? and did you need to knock down the tabs to make it fit if in fact you bought the h5?
Why did you need a new battery or was it just to be ready in case you need to?
mav47 on forum put in a UPLUS battery 140r battery, he pulled trim work for the fit without needing alterations or cutting.
Storm Ranger
Raleigh,NC
97 Explorer, 17 RAV 4, 22 Lariat Maverick Hybrid
I was in my local Super Walmart last week they had H4 Max battery that fit the Maverick.
scotty
pompano berach fl
dodge caravan
Is no need to go with the h5 diehard makes a h4 hybrid battery that works perfec, they h5 will fit but the plastic needs to ne remove firsts for intall
die hard at advance auto though is $220. on line uplus about $140
scotty
pompano berach fl
dodge caravan
The H4 is not readily available. No H4 at Costco, Sam’s , or Wal-Mart. They all have the H5 and H6. The H6 is actually ~$10 cheaper than the H5 at my local Costco.
don't see h4 at walmart as of yesterday on line
cyberdog
cyberdog
Ray
2023 Maverick Lariat Hybrid
Stock is actually or technically a T4 not H4. (Really same size physically).
Thankfully the H5 fits fine, just be certain to buy one with the vent port.
scotty
pompano berach fl
dodge caravan
I had read the h5 was a bit tall and need to have the tabs on the floor base that stand up a bit need to be bent down. Any truth in that statement. Thanks for your input
mav47
Carlsbad, California
Ford Maverick Hybrid, Toyota Highlander Hybrid
I installed this one, is a Group 140R and the same physical size as the stock battery so it is a true drop-in (no bending tabs etc). Stock mounting means it is locked in properly in case of a collision plus you'll end up with better physical clearances around the terminals.
UPLUS BCI Group 140R Car Battery, AGM-L50-UP Maintenance Free 12V 50Ah Premium AGM Batteries H4 LN1 Automotive Battery, 570CCA, 120RC https://a.co/d/4W6konJ
Currently $139 minus 5% coupon on Amazon. No core return needed either. Seems like a well-built AGM battery.
Works great 👍
It's not that it's too tall, but because it's longer than the stock battery dimension.
scotty
pompano berach fl
dodge caravan
But new battery did fit. Is it true you mad to bend down those tabs on the floor of battery section for the battery to fit? If so did you just take a hammer and pound them down, taking about 1/2 hr. or so?
Nemo
24 Maverick XL
Just to add my two cents. The tabs must be cut or bent down. I was thinking of placing some styrofoam, to make a flat surface, level with the tabs, but opted to bend them instead. Good thing I did. The little sensor box thing on the negative terminal, is almost pressed on with the plastic trim piece that goes around the battery area. Wouldn’t have any room for it, if I had placed the battery slightly higher. Got the H5 AGM from Walmart.
charlesb
Charles
canada quebec
Maverick xl hybrid 2025
Hey, does someone have hints / instructions on how to remove the plastic trim ?
