Oil Change Question
Gpp
Gil
Sanford nc
2022 ford maverick
Personally,i change my oil every 3000 miles,use 10 w 30 synthetic oil and of course change the wix filter.is this right or wrong I don’t know.been doing so for 50 + years with no oil related problems .the oil minder in my opinion is worthless.
Rivers90
Ben
XLT Tremor, Miata
Ecoboost engines should have the oil changed every 3500 miles if you want the turbo to last.
Turbo engines are harder on oil and some times direct injection engines end up with fuel in the oil, so it is a good idea to change it before an engine with out those things would need it. If you do lots of short trips you may need it changed early. I aim for 5k with full synthetic oil. I don't know what the factory oil is so that will get changed 1k or so miles. But I don't do a lot of short trips and I don't tow.
If you drive 3 miles or less to work every day that would be terrible for fuel in the oil. Very early changes would be called for.
Rivers90
Ben
XLT Tremor, Miata
There is no harm to the truck to change it early. But don't be late.
Pickles
Calvin
Kia rio, kia sorento
Like many people who have received their Maverick, I followed the suggestion of getting the "alien blood" oil changed out by 1800 miles. Took a road trip shortly thereafter and changed the oil again at around 3500, again at 8500, and then preemptively early at around 12500 miles for another road trip (done at a quickie shop) and they put me due at 15,100 miles but I'm at 15,800 and showing 63% oil life remaining.
Should I go ahead and get the oil changed or can I wait a bit longer and stretch it for the full 5000 miles in between changes?
Thank you for your suggestions.
Isnt suggested intervals 5-10k between changes in your manual? (I’m roughly converting from canadian equivelents lol) i did oil changes at 5k and then again at 15k-ish. The 10000k change was at roughly 30% life, oil life monitor estimated needing a change in about a month. Oil came out like you’d expect from any regular interval oil change. So unless you’re doing wild things with your little maverick between changes… you’ll be fine for your road trip lol
Shakesbear
J. R.
You’ve wasted a lot of money, and now you’re screwed. Mine says at the rate I’m driving, I need to change the oil in Jan 2024. I’ll probably not wait that long, but I sure as hell won’t change it 4 times before 15K miles. But you do what the aliens tell you 😎
JennyJoannSuebeeMcNash
Jenny
East Coast Florida
2016 Ford F150 XLT
Been doing a lot of driving, hence the oil changes. But, haven't spent a dime on oil changes.
Timothyd
On my Buick with a turbo I changed it every 6,000 miles with no problems.
bgn
WA
You're all wrong. I recommend every 25 miles or your engine and turbo will blow up.
No, I don't work for a dealer and my employer also doesn't make most of its profit from service. I have no idea what you're talking about. 😉
Tiger Dude
Skip
Louisiana USA
2023 XL
So in summary, you can change oil according to the monitor, according to people's statements of "what I do" or whatever you want. The weight you give to each recommendation is up to you.
Changing oil early will not hurt the vehicle, will only hurt your wallet, and will give more better oil to the recycling center.
Jenny
East Coast Florida
2016 Ford F150 XLT
Gonna stick with every 5000 miles.
I'll stick with what I was doing for my Honda hereafter: every 5000-7500 miles depending on driving conditions.
wax87
Stuart
Dallas South
2004 Avalon
Have you ever sent your 3500 mile oil in for an oil analysis? I bet if you did you woul dsee that you are changing it too often.
dhill59
2023 Maverick XLT
First oil change at 1900 miles by the dealer (no charge). Next oil change will be at 1 year or 10,000 miles. Which ever comes first. I only use fully synthetic at the weight recommended by the manufacturer (in this case, 0W-20). I've been doing this for years in all my vehicles, zero issues. The oil drained, never has looked very dirty.
