First Hybrid Oil Change Question
kevy
Kevin
Halifax, N.S.
24 Maverick XLT Lux 360
People giving opinions, as the saying goes; opinions are like butts, everyone has one.
Why not follow manufacturers recommendations? Why ask "opinions" of anyone you don't know (including mechanics)? I'm a retired Ford Dealer tech/service advisor (50yrs in auto repair including independent shop). I will never change the oil in less than 2000 miles, makes no sense. I had a 2022 hybrid Maverick, changed first oil at 7,500 miles. Sold the 2022 and now have a 2024 Hybrid Maverick. Always make sure to get a high-quality Oil Filter, I always use Motorcraft (oil and filter) to prevent any possible warranty issues if engine trouble.
Thanks Bob, I agree. I was wondering if the factory oil has any "break in" properties, that we should leave it in the engine for a minimum amount of miles?
mcc63303
St. Charles, MO.
sold 22 Hybrid XL now 24 Hybrid XL, 57 Chevy 454ci
I can't say for sure but there would definitely be "engine assembly lubricants" used in engine assembly that may be in the oil. I doubt any "break in oil" is used. I don't see any advantage changing oil early. Engine manufacturing has improved greatly over the years with less metal contaminants being a cause of concern. If a manufacturer that warrants an engine thought it would be advisable (save them money from warranty covered repairs) why wouldn't they recommend (and at owners expense) a first oil change early? With overhead valve ICE engines I change every 5k miles, my hybrid will be every 7,500 miles. Some driving conditions (towing, long idle times) may warrant sooner. Again, only using Motorcraft oil and filter.
MetalsGeek
Rough
Torrance, CA 90503
Down to just the Mav
When I changed my hybrid oil & filter at 39% life remaining, it still looked pretty clean & clear. It took 5.7 qts of synthetic 0W-20 w/ the stock Motorcraft FL-910S filter. The lower cover uses (15) TP-27 sheet metal screws (Mav uses Torx Plus fasteners), and the filter is recessed so you may want to have a filter wrench on hand. It's bottom mounted so easy to pre-fill. Oil Life monitor reset is under the INFORMATION screen (scroll down).
I've been trying to find out how to start the hybrid engine (idle leak check) for a year now so I'm excited to try the pedal-in-park approach. Dealer told me there was no way to do this. LOL
UPDATE: Full pedal in Park actually starts engine! (parking brake off) Now I want to try this in Engineering Test mode to see if the gas pedal might control the throttle. Improbable for sure, but you never know...
CurtisB
2023 Maverick XLT Hybrid
Its easy. Make sure your truck is in park and the brake is on! Turn the key all the way. Press down the gas pedel. Engine starts. Smile.
TedTX
Ted
San Antonio TX
Quick pulse to the floor in any mode starts engine, likewise when running at a steady speed a quick off the gas completely and back to wherever you had it before will switch it to battery only mode if reserve available. Works better in a Toyota hybrid. But can work most of the time to switch off gas engine. I use that to sneak up on my farm dog, she likes to greet my arrival and some of my landscape the headlights doesn't point down to see the dog.
shadow76
bob
TX
F150, Ranger
Everybody worries about first oil changes and I see a lot of guess. First off before the oil circulates in the engine it goes thru the filter which will remove the majority of the harmful particulates. I see where some have their oil analyzed which really only tells you what has settled in the bottom of the oil pan. If you feel better about early oil changes fine but I wouldn't fret it. Myself I only change every 10,000 miles and let the filter do it's job.
Oil analysis provides details on engine condition and allows early warning of a developing problem. Aircraft and heavy equipment (read potentially deadly/expensive consequences) undergo regular oil analysis to help prevent the above.
Oil filters do not renew depleted additives nor remove moisture from oil.
Please advise on your engine condition at the 70k point.
