OIL Change Discrepancy
Bmyers
Bryon
Mission
Hey All... Just wondering...Has this been a problem? I went to there dealer to get my 1st of 2 free oil changes and when I took a look at the work sheet when I got home I noticed that they had put in 5W- oil when on the oil cap it says 0W-?
I called into my service advisor and he said that it what it called for when he put in the VIN #
Any ideas why that would be?
It's called, why I do my own maintenance. I don't trust any of them. It's ridiculous and bs but it's true. When your car is serviced, you should be able to stand in there and watch them
Bmyers
Bryon
Mission
It's called, why I do my own maintenance, especially fluid changes. They're really not that hard and there are plenty of YouTube videos on how to do them. I don't trust any of them. It's ridiculous and bs it has to be that way but it's true. When your car is serviced, you should be able to stand in there and watch them
AlpineKid74
Graham
Gaylord, MI
2025 Maverick XLT
I have a 5 qt jug of Mobil 1 Full Synthetic and the specs do not match what the Ford Specification show, WSS-M2C962-A1.
Mobil 1 is showing 'Ford WSS-M2C960-A1.
I also add a quart of Lucas Oil Stabilizer when I do the 5,000 mile oil change.
Any reason why I should or should not use this since i bought it over a year ago?
Thanks
Ford Maverick OIL Change Discrepancy OIL_Cap&Spec
EDIT- I guess this Spec is not for the 2.0 EcoBoost. Put the wrong picture.
Ford Maverick OIL Change Discrepancy Moble1
Larrythelunatic
Larry
Massachusetts
Take your Mav back and tell them to do it correctly, using the proper oil.
If they try to upcharge you for the fullsyn, tell them that you’re due free oil changes for the vehicle that they sold you.
Hopefully they know what they sold you!!
New25ownr
RUSSELL
2025 Maverick hybrid
I called back the service advisor. After investigating ,he acknowledged there was a mistake on the paperwork. The initial paperwork listed the oil incorrectly. When the tech looked at the order, and the engine, his worksheet stated he put the correct 0W- in the truck.
Ranch
Sacramento CA
2023 Marverick FX4 4K
That the exact same thing that happened to me. I posted up thread about it.
You are 100% correct.
If the manual calls for 0W20 Full Synthetic. That's exactly what those "Free" oil change's should be done with.
As far as the service advisor, sounds like he's just Covering His A$$
As you probably figured out everything will be fine with your truck.
You now know what to expect next time.
24hrsun
2025 Maverick XL Hybrid FWD
I don't know that I would trust this oil change "paperwork" mistake. I would probably just do short oil change interval on this one if they are insisting the correct oil was put in it.
Ranch
Sacramento CA
If the OP is still worried about this he can have the service advisor show him the tech's worksheet showing the correct oil.
. In my case I read it with my own eyes and the service label the tech made backed it up.
Kpankow
Kirt
Vail, AZ 85641, USA
2025 Maverick Tremor
Ya. But it will be fine.
Change it out when you hit -20° temperature.
What? You never do?
Then you're fine. The second number is the most important one.
0w-20 and 5w-20 are going to behave the same in above frigid temperatures.
And before someone tries to "correct" me (you know who you are) by behaves the same I mean there is no meaningful difference and no sensible difference.
(I know who I am) As an Engineer and someone who has conducted thousands of scientific tests for the manufacturing community, you are right. But for the OCD enthusiast, they will still insist on 0W20 in Arizona.
dalola
Retired
SE Ohio 🇺🇸
lol... I think your SA has lied to you twice now. This makes no sense, based on his response to you the first time you questioned it.
Your call, but I would put this group in the rear view mirror... 🥸
I don't think you shared yet that I see.
What exactly does the line regarding the oil say?
It really says 0W and that's it?
Not what type, rest of the oil weight, quantity used, ect?
The Real Maverick
Jack
Thanks
A) That oil DOES meet Ford spec for quality
B) YOU purchased a jug of 5w-20. Your manual states 0w-20. That is the difference in the code.
You will be fine down to sub zero with what you have. No need to worry.
Wait... do you have a Hybrid or EcoBoost?
There are different pages in the book and different oil weights for each. But the "quality" of the oil is the same either way.
AlpineKid74
Graham
Gaylord, MI
2025 Maverick XLT
The Maverick has the EcoBoost in it.
Good, I am going to do next oil change with that then.
Thanks
