rileyfuego
Riley
Ontario, Canada
2024 Ford Maverick XL Cactus Grey
Your Mav looks great!
I"m going to keep looking I don't want to have the Hyperblinking issue with the Diod Dynamics as it would set off my ADD :)
Thank you!! It’s been a fun journey in the almost 2 years of ownership
Fair enough, I believe you or your dealership can disable the Hyperflash through forscan and it’ll go back to normal no issues whatsoever.
Let me know how the morimoto bulbs work if they fit! Hopefully they’re bright enough and don’t Hyperflash as well
Outstanding !
I’ve always like the black trim white paint look.
DavesMav
FL
These look great, for sure, but you got rid of the LED signature lighting from the stock Lobo tails by going to these fully halogen units.
Your stock tails certainly had this LED bar on the perimeter and in the middle of the light, which the fully halogen units do not have.
Ford Maverick New taillights on my white LOBO 1759165350997-hk
Ford Maverick New taillights on my white LOBO 1759165403649-x3
Upper right corner shows the LED bars that your stock tails have. These are on with the bulbs unless you modify the bulbs to only illuminate at full power, like many of us have done.
I wish the seller would make the LED signature lighting version with these gray/clear lens.
gsglassm
gsglassm
Greg
New Hampshire
2025 Oxford White LOBO, Honda Element SC
You are absolutely correct. When I pulled out the stock taillights I noticed the 4th plug which was an LED. Then pulling out the new taillight assemblies it did not even have a spot for that 4th light.
I was then at a "ah crap" moment deciding if I was going to send them back. Nope.. I like them to
much. :)
Nico_suave
Nick Jenkins
Las Vegas NV
2025 Ford Maverick LOBO
I saw these tail lights on Amazon and wanted them.
I started the install and quickly realized that I have all clear bulbs.
Swung buy the autoparts store and no one had red bulbs to fit. So I figured until I find some proper red bulbs I’m going paint some clear ones. Picked up some red caliper paint because of the heat resistance. I then Swung by my local Ford stealership and picked up 4 clear bulbs. I was shocked at the $19.95 cost per bulb!
Painted and installed them.
I think they work well for a temporary solution, but I really like these taillights.
Anyone have a link to red LED bulb?
Looking clean.
SM2535
NH
2025 EG Hybrid Lariat AWD
From one fellow NH Mav owner to another, I'll definitely keep an eye out for yours!
Grammaton
Ross
Covina, CA
2023 Ford Maverick AWD Lariat BAP 4K CP360+Assist
Try these for $50 a pair. They have cooling fans to prevent the LED's from overheating. I had Lasfit LEDs for a couple years until they went bad and replaced them with these. Just as bright as the Lasfits. You still have to disable "Rear Stop Bulb Outage" if Recall done that causes Hyper Flash at the Cluster using Forscan.
4257 WT21/7W Red LED Brake Tail Light Bulbs for 22-25 Mavericks: https://a.co/d/2fVBB6t
Grabber Rick
Rick
Sarver Pa.
07 Focus wagon 06 Silverado 4x4
Glad your factory bulbs fit your aftermarket taillights. These are what I got and the LED lights work with my XLT factory plug. One brake parking light blew out. Factory bulb would not plug into the socket. Had to find ones that were just glass at the end. The plastic at the bottom would not allow the bulb to fit into the socket. If I want LED ones I will have to try shaving the plastic down to possibly make them fit. I got these on Ebay from California supplier. $258 free shipping.
Ford Maverick New taillights on my white LOBO MavTailight
Brett3550
Brett
WI
Velocity Blue XL
I bought the same lights but on Amazon. The pics on these appear orange because of the clear halogens included. Just swap them out with Red LED's and White LED's for reverse. I love them!
Tail Lights
Bought these bulbs and they are bright. No grinding tabs (Plug & Play)
LED's
stangg17
Chicago
How do you modify the bulbs?
Brent@ANParts
Diamond Sponsor
Brent
Phoenix
www.autonationparts.com
Ford Bronco
Looks good, gives some real Stormtrooper vibes, which is my favorite look. I gotta say though that's the first time I've ever seen caliper paint used on a bulb! Hopefully you can find some LED replacements soon.
Grabber Rick
Rick
Sarver Pa.
Tail Lights
LED's
I tried replacing 1 blown out bulb with my factory one and it would not fit in the socket. The bulbs that come with mine had no plastic base just glass with the filament wires. Did your lights come with bulbs? Did you leave them in or switch them out? If so how did you get them to fit? Mine would not push in. I did not want to break the bulb socket. My plug fit in without using the included adapter plug. Maybe Amazon ones are different than mine. Are the tabs on yours plastic or metal? Mine have plastic studs that push into the tabs.
Maverick_Dave
KS
2025 XLT Mav. 2000 Explorer. 1986 Camry
Brett3550
Brett
WI
Velocity Blue XL
Yes, my lights came with glass bulbs. I had to replace them with 7440/7443 LED's. You probably are trying the wrong LED's. Look at the difference between 3157 and 7440; the physical difference is noticeable.
