MPG related to MPH
17629134
unionville,mo
2026 for maverick lariat with 2.5/hybrid
MPG expected while driving 2026 maverick w/2.5/hybrid at constant 60 MPH
FWD or AWD?
More or less than 4,000 miles?
Both questions above make a difference.
Suzukiridr14
Frank
Sarasota Florida
I would guess around 35-38 mpg at 60 mph. Drive a little slower, on basically flat land, and you will get in the low 40's.
kevink
Kevin
Oklahoma
2025 Maverick
I would expect over 30. But I haven't had the opportunity to check at a steady 60. Most of my trips that include 60 also included long periods of 75-80, where I drop closer to 27.
MaverickDragon
Grand Canyon, AZ
AWD is a trifle lower as noted.
Terrain makes a big difference too.
So does temperature, wind, tire pressure and vehicle load being carried.
To get a close approximation for your vehicle while doing your 60mph, go to trip 1 or 2, and hold down the "OK" button to reset it. You will shortly have the mpg displayed for that speed.
Ryom
PA
2025 Lariat 4K BAP Eruption Green
Gently rolling hills and warm weather A/C off? 50MPG is possible.
Cold weather and mountain roads? 25MPG probably.
Flat terrain and A/C on, probably get EPA rating.
Too many variables here without specifics.
Mavster Mechanic
Hybrid
Close enough for you?
You will gain MPG if you are slow enough to allow the engine to go off sometimes. Above 60 the engine rarely stops unless it is steeply downhill.
Ford Maverick MPG related to MPH 1780863092336-av
DWV
Don
charlotte nc
2024 Maverick
Topography and the way you drive are also important. You will get lower MPG if you use cruse control on the hwy in my experience- since it doesn't take full advantage of the topography.
betlouboo
Bette
Medora, IN
26 Ford Maverick Hybrid
my '24 got around 34 mpg when driving the interstate.....I have a 26 now and driving around 55 mph I'm getting 45 mpg.........the '26 I've had 3 days now
Waterick
Laurens county SC
Is your '26 FWD or AWD?
Idahomaverick60
Scott
24 lariat/4k/FX4
My maverick is very sensitive to wind. A slight 3-5mph breeze will add or subtract 1 to 2 mpg depending on head or tail
stevj
Stev
Pacific Northwest
2026 Maverick
Yes. You are correct to expect MPG to happen while driving at 60 MPH.
Joester
UPSTATE NY
2022 Maverick ECO, FX4, 4K, 2023 Bronco Sport, 2024 Escape Red Line
I guess I won't complain about my '22 ECOboost/FX4/4K getting 35-38MPG on the highway between 72 and 75MPH. At 3-4 car lengths behind a semi at the same speed I can draft it to right around 40 (but I don't like being that close)
