Bob The Builder
Butch
Vermont
W
Good welders are worth their price.
Whoever welder that I hope they know how to run a grinder.
All the tradesmen and women who work nukes are worth their price and then some. :) (y)
apstephen
FLorida
Maverick Lariat 2023 to 2024 in waiting
my concern is that during the actual winching in a badly stuck condition, any sort of angle could "tweak" the unibody. I've done my fair share of winching, but always on a body on frame vehicle. This rig bothers me on many levels.
Not my vehicle or my money....so let us know how everything turns out!
GPSMan
Many
Right off, let me address the obvious question: "why would you put a winch on a hybrid? "
...because it will get stuck off road more than a 4wd ecobost. 98% of my driving is on pavement ,so I bought a hybrid ,but I have modified to go off pavement. I found a mid-90's Jeep bumper on e-bay for around $130 to modify to fit the Mav.
I was asked to show pictures of the build, so here they are:
The whole front facia needs to be removed. Once removed, you will see that the body painted bumper / grill surround are a separate piece from the black plastic "diaper " (I hate plastic cars) . These two pieces easily separate by pulling the metal tabs attaching them together. Save this diaper and tabs for reinstall if you loose your nerve, or come to you senses and want to return it to stock.
Right below these two bolts attaching this bar across the bottom of the front are the 1" stamped holes used to tie down your Mav when it was shipped from Mexico. These two tie-down holes will be the primary bumper attachment points.
A 1" bolt is welded to a piece of angle so that it will tightly fill the shipping tie-down hole. A piece of flat square stock with a slot cut into it to accommodate the "fin" at the top of this crossmember is welded to the angle iron so that the crossmember is sandwiched between.
This shipping hole sandwich is repeated on the the side. From here you stack the necessary brackets to hold the bumper. These are made from 4" channel or 4" sq tubing.
The channel bolts to holes hanging from the bottom of the steel stock bumper (nothing was originally attached there - how lucky was that.)
The 4" sq tubing is either bolted or welded to the slanted body piece directly behind (I was lazy and threw a welded on it)
This top piece of channel is the attachment point for the upper portion of the bumper you can see the exposed bolt in picture of mounted bumper. Also the 2" angle iron showing in previous picture has two holes drilled to match up with two holes in new bumper lower section.
Mock up cardboard pieces to blend in Jeep bumper to opening. Cut these out of 16 ga scrap. A small black-chrome bolt attaches to flange at bottom of facia opening.
WARNING: THIS PROJECT WILL REQUIRE FABRICATION SKILLS. THE ABOVE IS NOT A STEP BY STEP INSTRUCTION. BUT JUST SOME TIPS TO SHOW THAT IT CAN BE DONE.
One of the top 5 mods found on this site.
Top 5.
Those talking about the welds didn't read. Owner did a "mock up" himself without much practice then took it to someone else for final welding.
NextTruck
PA
2017 JeepGC Overland, 2010 Tahoe
Welds are a little rough.
NatePabrant
Nate
24 Tremor
Fascinating personal DIY. Well done.
Is a winch not normally possible to install on the Mav?
I was just looking at cattle guards or brush guards and realized that wait, what about my Pilot360 sensors…
Moby
Richard
Fort Erie
Hummer H3 sprinter van 65 chevy 11 Doka syncro
I also have been trying to figure out a way to put a winch on my Tremor . Purchased a badlands 5,500 lb winch. I started trying to make a bracket out of aluminum . In the end I did not want to mess up my front bumper ,so I just made a mount that slides in the trailer hitch . My main concern with this design ,is the loss of approach angle . But good for you in pushing the boundaries . Lets all hope someday a company will make a winch bumper for the maverick.
thev8man
Booyah 👊🏽 😁 👍🏽 🇺🇸
Can you tell me if your trim rings are metal or plastic, and where you got it?
Montana
All this and no fog lights, or a light bar of any sort?
But I have to agree with others about the unibody. You see the Subaru boi's do it all the time and it might be enough to get you out of the mud, but anything serious and you are going to seriously tweak something. I'd like to see if there would be a way to mount one hidden behind the bumper for that reason alone, but anything else is overkill. Nice to have though, especially in rural area's. It's either freeze your ass off waiting for a tow hoping you have cell signal to even call one and they are going to do the same thing pulling it out, or do it yourself. But I can't say I'd invest in it for a Maverick. Metal bumpers on a Maverick are basically the same as brush guards, and some refer to them as "damage modifiers", because they usually just cause more damage.
RZ2O16
Robert
Southside Chicago
2016 Honda Pilot EX & 2020 Subaru Outback Premium
This is the first time I've seen someone do this! It looks pretty good.
SkeeterB
The Woodlands, TX
What's the difference between a winch and flat towing?
GPSMan
Many
I think force to pull a free wheeling vehicle will be slight.
Winching one stuck on ice or light snow, forces will be pretty slight.
Winching out of mud/sand or up a slope people are worried forces will be great and bend something. But, if you are stuck that bad, SOMEONE is going to have to pull hard to get you out. So I'm gonna say if you are buried deep, what have you got to lose? 🤷🏻‍♂️
Maverickman74
Shane
Maui HI
In no way would I put a winch on a unibody vehicle, you are just asking for trouble.
I've probably used it 30 or 40 times over 4 years with zero issues other than my solenoid box having a crack and filling with water and needing replaced. Home made mount on a home made bumper with 6 bolts going through 3 holes on each side in the front stamped structure. Also this truck has a ton of rust. Still holds together. Even did anchor pulls where I was winching but my rear bumper was tied to another vehicle pulling.
Ford Maverick Mounting winch bumper on a Maverick IMG_20231111_125747_440
NoVaJimmy
KCMO
Lexus GX 460
I've wondered the same thing. Why not just put one of those base plate kits on especially since they attach further back on the frame member that the FX4 hooks bolt into. I get that the FX4 has an added anchor point welded in but the base plate kits I've seen have reinforcement pieces bolted on to that frame piece. Seems like it would be a heck of a lot easier to fabricate an attachment for the base plate than it would to fabricate what is essentially a base plate.
