Mice/rodent entry point behind rear seat
  • Thread starter Deleted member 7089
  • Start date
  • Watchers 2
Deleted member 7089
Guest
A redditor identified an entry point for mice behind the rear seat. There is a vent there that has easily chewable flaps (first two photos are from the Reddit post) :
Ford Maverick Mice/rodent entry point behind rear seat venthole2
Having had this issue on my previous vehicle, I modded the vent with wire mesh. I used 1/2" square which worked fine for me on my previous vehicle. Some might argue that it's not small enough, so consider 1/4" mesh instead in that case. Guess we have burly field mice up here 😁.
I folded the sides 1/2" with additional 1/2" protruding wires at every inch. Drilled pinholes into the plastic and passed the protruding wires through and folded them flat on the other side. Does not impede flaps.
Ford Maverick Mice/rodent entry point behind rear seat vent1
Ford Maverick Mice/rodent entry point behind rear seat vent2
Ford Maverick Mice/rodent entry point behind rear seat vent3
Last Truck Ever
2023 Hybrid Maverick XLT
What's the actual purpose of this vent? Never had a truck with one, what benefit is it? Would seem to be simpler just to block it.
LtCasual
Paul
Minnesota, USA
2023 Maverick XLT
Pressure relief, if you're running your heat/AC using outside air the extra air has to go somewhere. Out this vent!
Last Truck Ever
Ah, live and learn, just googled it, too. How did I not know this, lol?!
The Weatherman
Dean
KY
Thanks for posting that hack. I had the wire harness chewed through earlier this year, so they are out there looking for something good to eat and a warm place to stay.
Gardner79
Michael
Plano, Texas
2023 Ford Maverick, 2017 Toyota Sienna
Anyone here use Honda's rodent tape? I assume you could just tape it on those flaps as an alternative.
acutturi
Al
Oxford, MS
2023 Maverick XL 2.5L Hybrid Cactus Grey
I have used the Honda rodent proof tape on my Odyssey. It doesn't work (at least the chili flavored one didn't work for me). Replaced the same sensor two times due to rodents.
Edge Haley
Edge
CARBONDALE-Atlanta
PORSCHE
Honda tape is for wrapping around electrical tape....not effective to allow air flow to get thru....it would block the vent...Honda tape does have hot pepper in the tape to keep rats from chewing but this would be the wrong application.
Gardner79
Michael
Plano, Texas
Well, I was thinking to just put a layer on outer part of the flap only, since that is what got chewed. This does assume the tape is thin enough to not interfere with the flap operation, and the tape adheres well to the flap.
Gardner79
Michael
Plano, Texas
Thanks, I am pretty interested in this topic right now. I discover a rat is eating the windshield wiper tubes on my toyota sienna. Strangely, havent discovered any other damage yet. This vehicle is parked in garage and discovered other evidence of rat there, so am setting traps. But, my brand new maverick gets parked outside! So yeah, I am researching various ways for rodent deterrent in vehicles.
acutturi
Al
Oxford, MS
I tried peppermint oil, Irish Spring soap, and the chili flavored tape. None worked. Then I put little green chunks of rodent poison around the engine using zip ties, and that stopped the problem. Never found the dead rodent in my engine or on the ground.
MetalThunder
MetalThunder
Blue Water Area / Thumb Coast "Mishigami"
www.automobile-catalog.com
2024 Iconic Silver AWD XLT 4K Lux Ecoboost
Just curious anyone know what the outside/underside initial area of entry looks like - possibly stop them there - maybe someone has a lift ? don't feel like crawling - saving my back for tree planting.
Cheers
rivermaverick
Fort Mohave AZ
I believe it's a federal requirement that all vehicles with AC must have the cabin vented to prevent the occupants from being suffocated by a refrigerant leak.
rlhdweman
Random Lake Wisconsin
These vents have been around forever, my 50 year old Cadillac has them & so did all my 70's GM cars, but they were placed near the door striker & would be hard for a rodent to crawl up smooth sheet metal. When running your heat/ac fan on a high setting it would be hard to get air moving unless you cracked a window without these.
