Mice in my Air Box
Cancunbadlands
Cancun
Cancun
Oh boy!
REDRUM
Central Jersey
2025 Maverick XLT
Or squirrels?
El Kabong
Carnation, WA
Little critters love hidey holes. Airbox inlets tempt them to explore, then they find the airbox and feel safe inside the box.
You need to get some rodent repellent and coat the inside of the intake, airbox, and general area around the engine bay, maybe even get some of that tape Honda sells and wrap your exposed wiring.
Clarkdonbran
Better than crabs on your organ?
MaverickDragon
Grand Canyon, AZ
A piece of hardware cloth (1/4" steel mesh) over/in the inlet will prevent ingress.
The rest of the under hood area is open season.
I find propping my hood open works, as they like places to hide, not the open air.
You can get battery zap traps that are baited with peanut butter at a hardware store.
Ryom
PA
I sprayed ACF-50 corrosion inhibitor around the engine bay for the primary purpose of keeping things uncorroded. However, the slickness should help deter nesting and rummaging by critters and if the cabling is tasted-tested the taste should be a deterrent as well. It's good for about 2 years before a respray is recommended.
Chops
Lobo
Only way in is through the air intake on the grille above the radiator. Only way out alive is that same way. Turbos hate mieces to pieces. Hopefully they did not chew a hole in the air filter!
For no reason at all I was just poking around under the hood my 3 month-old Maverick and discovered this:
Why??
Check your cabin filter behind glove box. I have found nests there three times. Also corn stored in my hybrids air box
Tunnelman
Stan
Emery MI
2025 Maverick hybrid XLT, 2014 F350 6.7, 2007 Ranger Super Cab, Sport
Could be chipmunks. I had a problem with them for years. They would fill the air box with pine cones.
Jensen3
Louisville KY
Peppermint spray works well. I used it to get rid of mice in my Honda.
