Maverick Hybrid recovery points, what to do when stuck?
JP4AZ
Phoenix
If you need to recover a vehicle(Maverick) from the front and it does not have a tow hook. You can use these round "Soft Shackle" around the frame, or the hole in the lower control arm (below the left side green arrow in the photo)
Link to soft shackle and recovery rope: (soft shackle is the smaller loop things)
https://www.ebay.com/itm/155871900102?hash=item244ab071c6:g:lMgAAOSwCO9keAtx&amdata=enc:AQAIAAAA4FL73B5rDN+0AwJvRW/YFgP4nac6yEzoUfSU0bPhl0+3iW+0tG6jlE0sdJcnLk8CpmIXNPm2ihWqqpafRpBVk7P+xGn2eRVPa1RxluGgU5qd8Ywez4d+Gkgj3N2+ROE0QHw+T/i8RIrCF1tt0t9mScp4O115LNWsVPrGuvWoFg6ujAJ5cNqoK822fodyZ6REimAyf2ZFEl/snGsU6ijo6StybHcErDgcCl/WVHrlm70hd8ewcP5Mz76ranp/rW33YwSxFYRG7GfX2DqjFWfYbYVvsWZw7SUrV+54gcpmEZEE|tkp:Bk9SR-Ssu7WSYw
Ford Maverick Maverick Hybrid recovery points, what to do when stuck? 4_fr_larm_under_arrow
Ford Maverick Maverick Hybrid recovery points, what to do when stuck? s-l1600
fossil
ernie
ohio
looks good. I opted for a 7/8" rope but think I'd be better served with a 3/4"
If you don't want much stretch 1" is ok. 10' bridle not shown
Ford Maverick Maverick Hybrid recovery points, what to do when stuck? 20231209_131246[1]
JP4AZ
Phoenix
I just purchased this recovery strap:
https://www.amazon.com/dp/B09Q89H6VQ?ref=ppx_yo2ov_dt_b_product_details&th=1
And this for the Hitch:
https://www.ebay.com/itm/354999112890 (Make offer of $23.50 and it's yours) all lower offers get countered at that price.
This is for when we go up to the snow. There is not a real good place to hook up the front end of the Maverick. (See the post above has a link to possible spots)
Just and FYI. The recovery rope has about a 30% stretch and the recovery straps have about a 20% stretch.
fossil
ernie
ohio
For trucks, SUVs, and larger rigs, purchase your Factor 55 KERR based on your vehicle’s gross vehicular weight rating (GVWR). A properly sized rope for typical SUVs and trucks is one that has a 4:1 to 6:1 minimum breaking strength to GVWR ratio. For larger vehicles (Unimogs, EarthRoamers, EarthCruisers, heavier military trucks, etc.), a 2:1 to 4:1 ratio may be acceptable. If you use a smaller and lighter KERR, rope breakage might occur. If too large and heavy, the rope won’t stretch enough, reducing the maximum kinetic energy assist. The KERR must be suited to the GVWR of the lighter of the two vehicles used in the recovery process.
https://www.factor55.com/c-recovery-ropes
Maverick aprox 5,000GVWR X 4 = 20,000. X 6 = 30,000
fossil
ernie
ohio
Even if you do, it's a unibody, not the same as pulling on a frame.
That's right and why I advocate for a bridle to spread the load and a stretchy rope to soften the pull. Knowing the limits of the tow points and using that space between your ears is good practice.
GPSMan
Many
GPSMan
Many
There is an older post that is closed, trying to revive the question. The pic below shows one of the 2 holes in the front (the old post had some discussion on their use but didn't answer the question). The Ford instructions tell you NOT to use chains, cables or straps "WITH METAL HOOK ENDS"!
Can anyone shed light on what is to be used, that is not metal, to tow a hybrid Maverick when stuck?
This below is the Ford Approved Method;
Ford Maverick Maverick Hybrid recovery points, what to do when stuck? IMG_9072
JP4AZ
Phoenix
Post #54 shows that those metal hook things at the end do not fit the Maverick
GPSMan
Many
Incorrect.
Different fixtures.
Take a closer look.
Ford Maverick Maverick Hybrid recovery points, what to do when stuck? IMG_9073
I only got the ones highlighted in yellow. Those do not fit. One of the other shapes will.
Pictured is a 3-way "universal" device.
Hot Runr Guy
West Chicago, IL
Incorrect.
Different fixtures.
Take a closer look.
I think the mini-J hooks might be the ones,,,,,
HRG
Ford Maverick Maverick Hybrid recovery points, what to do when stuck? 22930__72330__26320
GPSMan
Many
GPSMan
Many
But in true Ford fashion, the use of "spacer blocks" is expectedly vague.
GPSMan
Many
