Maverick FX4 off-road capability?
Zepper
zane
Porsche Cayman S, Maverick XLT (Alto Blue), Altrak
You are incorrect, sir. A 235 tire and a 225 tire do in fact have different "heights". The poster you quoted is correct. All Mavericks will have the same 8.3" of ground clearance UNLESS fitted with the 235/65R17 Falken Wildpeak tires giving that particular truck 8.6".
Thats not true the rear suspension is different in AWD models. There is no possible way that the ground clearance is the same in two trucks with completely different suspension, regardless of what ford says, you can bet your life on it but I wouldn't.
Rivers90
Ben
XLT Tremor, Miata
Approach departure and breakover angles will what limits you when going off pavement on these.
Ground clearance is limited by the low hanging front bumper, but being low in the front gives much better MPG.
You could lift it a little and get (make) a higher clearance bumper. CV angles limit how much you can lift it. You are limited by the small wheel wells in going to a bigger tire size. It is uni-body so you can not do a body lift. No low range, but if you get the 4k tow it has a lower gear ratio that would help some.
At some point you would just be better off with a ranger tremor or the bronco. If I was going to build an off road trail vehicle I would start with something else.
But it should be fine on dirt fire roads and easy trails, and should keep up with subaru's and other non low range awd's. Subarus come with the same 225/65R17 tire size so it is very comparable.
So the best off road Maverick would have all 3 of these options FX4, 4K, 235; fx4 (skid plates, off road modes, hill decent control), 4k tow (lower gears), 235/65R17 A/T Tires (bigger tires help you from sinking as much in soft sand and mud, transmission shift points will be programmed for the bigger tires too)
CLH917
Travis
Madisonville, LA
So because they have a different rear suspension set up, it HAS to have a higher ground clearance? What evidence and proof is there to substantiate that?
Also, it seems you abandoned your 225 and 235 series tires have the same diameter argument. Must have looked that one up and realized you were incorrect.
Krunty
Southern Ontario
22 Maverick Fx4 and 2016 Mazda 6
This…
Ford Maverick Maverick FX4 off-road capability? 92F04A5B-40D9-419C-8B72-1E2966124E49
Sir, 235 and 225 are width of the tires in mm. The tires have identical side wall heights = 65mm, both on 17" rims.
That's not what the 65 means. The second position in tire measurements is Aspect Ratio or percentage of width as sidewall height. So 235 * 65% = 152.75mm. 225 * 65% = 146.25mm.
Rkbrumbelow
Robert
Cedartown, GA
HCH2, Hybrid XLT on order
So, let me get this straight, you are saying tyre diameter /2 is not tyre radius but some other magical wizardry that when multiplied by the aspect ratio gives the height of the tyre?
talk about your non Euclidean geometry
In P-metric sizing overall tire diameter is not a specification. Nominal width, aspect ratio, rim diameter.
vezpa
EMG
IL/IN border
Too many to list.
Way too many people here who should be ordereing a Ranger instead of the Maverick.
Rkbrumbelow
Robert
Cedartown, GA
But it lists the diameter of the tyre it’s highlighted in yellow next to the words “diameter tire inches(mm)”
mamboman777
Josh
NRH, TX
Don’t forget Ford warranties the FX4 version if used for Off Road vs. no warranty using other versions of Maverick without FX4 off roading.
I wonder how the warranty department at Ford defines "off road."
That's not a value listed in 235/65R17. It's an inferred value. In fact, it's not uncommon for same size tires to have 1/2" or more difference in overall diameter.
(235mm * .65) x 2 = 305.5mm + 431.8 (17 inches) = 737.3mm
Air Shootist
IL
Fully loaded 2022 Maverick Lariat
I am 100% taking the Mav down sandy logging road trails, 2 tracks, to the farm, creekbeds, etc. I have done it with my Mazda CX-7 FWD and always made it through, with no lack of worry about getting stuck, though! Haha
With the Mavvy, there will be no worry of getting stuck with the stuff I do, plus it has .25 - .5" higher ground clearance than my Mazdarati - which has never gotten seriously stuck and I've done crazy sh*t with it. Anyone who thinks the Maverick is a rock crawler, however, is probably in for some unpleasant realities...
This is my first vehicle with AWD. I am super excited. It will be pushed (close) to the limit.
Rkbrumbelow
Robert
Cedartown, GA
Again you are saying diameter does not equal diameter.
Not worth discussing with you.
Agreed because you clearly can't read. I initially said "65" is not 65mm but 65%. Nothing about diameter or radius.
Rkbrumbelow
Robert
Cedartown, GA
/plonk the discussion is about the height of the tyre
