So I am at 20K miles, 2024 XLT Hybrid
1. So far I have just changed my engine and cabin air filters. Will using a K&N engine air filter actually void my warranty?
2. I am not getting near the average mileage that is advertised.
4. I purchased the extended warranty, the suspension behind all 4 tires are burnt orange rusty, I will be taking my truck in for the latest recall, is it part of the warranty for them to fix the rust issue?
5. Will increasing my tire pressure help with milage?
6. Should I get a transmission flush and new filter at this milage?
Any suggestions other than the ones listed would be appreciated!
PS I changed my cabin air filter with a carbon one today, It looks like they forgot to put the arm that you are suppose to unclip on the lower right side of the glove box, or did they just discontinue it after 2023?
- Should I check spark plug gap?
- Should I clean the MAF, will this void the warranty?
- Should I clean the MAP, will this void the warranty?
- Should I clear the driver memory log, and can I do it the old way of taking off the positive terminal waiting 25 minutes, turn on the key to start and leave on for 15 minutes, or will this work on a hybrid, will this void the warranty?
- Should I clean the intake of carbon? Will this void the warranty?
- How can I do the "Italian Tune Up"? I read that you need to get your engine to 2000-3000 RPM for about a 20 mile drive. How can I get higher RPMS? Put it in trailer mode?
