Lug nut torque
Sleeper 7
Steven
NH
18 Fusion 14 Ram Dump 23 Maverick XL
Spec for 14mmx1.5 is 85-90 ft lbs. Not sure why Ford says 148. I torqued my new wheels to 100. On a side note Ive never had any shop torque wheels correctly. They send it with the impact gun and call it good.
rivermaverick
Fort Mohave AZ
Ford Maverick, Ford Fusion (UK), MEV Sonic7
It's important to tighten the wheel nuts evenly and in the correct sequence, you are also clamping the brake rotor, uneven torquing can warp the rotor.
billbillw
Metro Atlanta
'23 Maverick Lariat FX4
I do most of my tire shopping/rotation at Discount Tire (not Mavis) and I visually see them check every lug with a torque wrench once the vehicle is on the ground. They do good work.
Aspidochelone
Michael
A nearby cornfield
2023 Maverick Lariat
Anyone else have low torque on factory tires? ~5000 miles just bought a torque wrench and they were moving at 100-120 ft-lb. Getting ready for future tire changes and bought an impact too that goes to 150 ft- lb on low.
Bigred
McCormick, SC
2002 F250 4x4 7.3 Diesel, 2024 Maverick Lariat 2.0
My 02 F250, snug em, then tighten, then tighten again. All with my Earthquake battery impact. I do use a torque wrench on the Lexus since it needs only 80 ft lbs.
Bigred
McCormick, SC
Agree, Discount Tire does good work
AlsMaverick
Allen
Cincinnati
2024 Maverick Lariat FX4 w/4k Tow Build Date 12/5
That torque spec is for 8.8 grade studs. It's common to have 10.9 grade studs which has a torque range in the 140 ft-lbs. IIDK what the Maverick studs are but my guess is 10.9.
Automan21
Mel
CT
‘23 XLT Eco AWD 4K Tow
Yeah always tight then a quarter turn after. Never had an issue.
mp24
NE
2022 Maverick XL
NJBob
New Jersey
Are those torque sticks they use with impact wrenches accurate? I am not even sure how they work.
I have yet to see anyone use a tourqe wrench on lugnuts.
NoVaJimmy
KCMO
Lexus GX 460
Tiger Dude
Skip
Louisiana USA
2023 XL
They flex enough to keep the nut from tightening. They work fairly well, I've seen videos.
