Lug nut specs?
greenweever
Peterbuilt
What color are the lug nuts underneath the XL wheels? Chrome?
RNC185
Russ
Amelia Island, FL
22 Ford Maverick Lariat
Just got this from Gorilla for Maverick.
HRG
These are not the two part lugs nuts that have swelling issues where the lug wrench no longer fits are they? I hate the cheap ones the OEM uses.
Sembazuru
Wilmington, de
2023 Maverick XLT Lux Hybrid
A lot vehicles are specked at 80-85 but we never had a problem at 100.
Hopefully you used an actual calibrated torque wrench. I've seen many shops run lug nuts on with their air-impact drivers. Maybe that has changed in recent years.
I've destroyed a couple cross lug wrenches trying to do a tire change on the side of the road for myself or my friends (either twisted the shaft or snaped the weld in the center). I don't know what torque they were put on, but I had trouble breaking them using my full weight on the cross ends (about a foot from the center-line of the cross lug wrench) with my almost 300 pound fat ass. Damn near 300ft-lbs to break them loose is way too tight.
MavDave
Houston
2022 XLT
If we more than snugged with an impact, about 1/4 trigger (very slow) and 2 or 3 pops.we would get a slight verbal beating. One guy was fired after 2 weeks and 4 warnings, he just didn't get it. We had the mechanical clicking torture wrenches, with an extra set in the tool room. The GM sent them off monthly for calibration check. I put a set on my brothers car and he curbed it a week later blowing the sidewall he swore they were torqued to at least 200. 100 foot pounds is more than most people think.
Sembazuru
Wilmington, de
Yeah, that is the way to do it. Not all shops do that (or maybe they do now, so I might have old information).
MavDave
Houston
2022 XLT
No, probably less shops do it now. I spent 3 years in the tire shop before starting in HVAC. I started HVAC in 2008, and we were one of the only shops in the aera still actually torquing lugnuts. Sadly most people would rather do it fast than do it right.😞
MostlySafeBear
San Francisco, CA
(Eventually) a Ford Truck
This seems like a very stupid design decision from Ford, and it's annoying to know that they have known about this flaw for years, but refused to correct it. It's something so easily fixed, in the scheme of things.
When I looked on the Gorilla lug nuts web site, it appeared that the correct parts were "14MM x 1.50, Acorn part # 71743"or "Acorn open end part # 70743", but I couldn't find those on Amazon.
I did find some similar ones, but nothing exact.
Which ones do I need?
Hot Runr Guy
West Chicago, IL
This is what Gorilla sent me yesterday, for a Maverick.
HRG
Ford Maverick Lug nut specs? Gorilla Maverick lug nuts
MostlySafeBear
San Francisco, CA
HRG
So both black ones are the same? The measurements seem off, as 7/8 is bigger than 13/16.
Hot Runr Guy
West Chicago, IL
You get your choice, if you want 7/8" OR 13/16" hex size. These aftermarket lugnut makers offer a lot more flexibility.
HRG
MostlySafeBear
San Francisco, CA
HRG
Thanks for the information.
Crazyal
Al
Alberta
2022 FE, Lariat, Lux, 4K, 2022 Ford Edge ST
You better check that torque spec.its way to high.should be around 75-80 ft lbs
Wheel torque is 148ft lbs
