Looking for a budget roof rack solution
Timothyd
Just returned from our vacation. Yes it looks like ass. But it worked perfectly and stayed anchored securely.
Probably won’t be using it again for another year so staying under $200 made sense to me.
You should try one of those cargo carriers that fit into your hitch. Much easter to access.
vabchusa
Va Bch, VA 23452
2015 Ford C Max SE, 2022 Maverick First Edition
Check Ebay They have lots of roof carriers that will work starting at about$80
Payton333
chris
Honda civic
This is awesome thread. Watching it.
I think you could still do a bed rack if you DIY a bed slide out tray. You wouldn't need to flip up your tonneau cover.
Do you have a link to this thread. I’m interested!
BlueSnake77
Rochester NY
They also have inflatable roof racks.
mspmms
'MERICA
2022 XL Ford Maverick
If you want a really reasonable option (non-locking) I bought this off Ebay ($65) and it fits very well.
https://www.ebay.com/itm/254369960945
Comes with three different sized clamps. I took the smallest ones and straightened them out a bit (clamped in a vise and bent by hand). It fits perfectly on the black channels. Front and rear racks are set about 3/4" different in length.
All in all, a good super cheap solution. I will grab a photo of it on the truck a bit later today.
Showing out of stock.
Looks like a similar one for $69.00 at Amazon
link
mspmms
'MERICA
Glad I clicked on this thread - I had shopped for some cheap racks months ago but nobody had any experience with any at that time. $65 is cheap for a set of racks. I already have a cheapass cargo basket this will complete the cheapass circle. :ROFLMAO:
🙏 Please share your cargo basket information for a fellow "cheapass"
BoboysTruck
Virginia
F150, Focus, Juke
I was referring to this thread.
If you're referring to the slide out tray, that's what I built after watching of YouTube videos. Just search PICKUP TRUCK SLIDE OUT TRAY on YouTube and you'll see a bunch of DIY builds. Here's one.
Mavonorder
Pete
Camry
Here is a photo of the installation. Pretty low profile. Misses the antenna nicely. Fairly minor wind noise (I've added a kayak rack which does up the noise). But the rack fits really nicely and only takes a minute or two to remove or replace once you've set it up. I recommend writing front and rear on the appropriate racks as they are slightly different lengths
Looks like a nice fit, are the brackets painted or rubber coated? After use, any signs of paint wear? Thanks for sharing!
Inspector1
NIgel
Victoria BC
2022 Ford Maverick XL
The brackets are painted but come with some stick on rubber pads. Not fancy but they work. No paint wear so far. The supplier I ordered from is showing out of stock now but Ebay has lots of sellers listing the same brackets. They are pretty generic.
Mavonorder
Pete
Camry
Good deal! I'm pretty disappointed the maverick didn't come with a factory option for bolted down roof rails which seems to be common option on every suv and pickup. When I ordered my Mav, I told the sales guy I wanted the approx. $700 roof rack option. He said since it's a dealer install, don't order it, but get it later as it might slow down my build date. He didn't mention it's nothing more than a $100 eBay type rack system. Glad I didn't pay many hundreds more for it.
Decayed
yes
a car
It was something I found at walmart a few months back when we went on vacation. Turns out it wasn't cheap at all I bought it because we needed it fast.
Mavonorder
Pete
Camry
I like the beefy hand knobs, no fumbling with Allen wrenches needed. Not readily seeing other racks with hand knobs. A tiny bit of added wind resistance/noise maybe but worth the convenience. Those tighten the crossbars down to the brackets correct? Looks like those would make adding and removing the entire rack quick and easy and for the rack to be securely tightened down.
UPDATE
Received my clamp on rack and a j-bar and they are not very compatible. The bottom of the cross bars for the rack are 2" wide and the slots of the bottom bracts for the j-bars is also 2" wide so none of the cross bar will seat inside the slots. It's too bad all the diagrams for these universal parts is not more exact/meaningful. The bracket measurement shows the width from bolt to bolt (3.5") and not the width of the slot for the crossbars to fit inside. My j-bar was missing all the bolts, washers, hand clamps, etc. so it had to be returned anyway. And I found another brand of j-bar which showed a measurement of 4.3" from bolt to bolt on the bottom bracket so I ordered it hoping the slot will also be wider and allow for some of the crossbar to seat at least a little down into the slot. The new j-bar is supposed to arrive on Wednesday and I have a planned trip for the following Friday morning so not a lot of time to get this all worked out.
Smack
Minneapolis Minnesota
Ford Maverick 2022
I had Yakima round bars so I did this.
I have the Ford tri-fold tonneau cover.
TruXedo Elevate TS RailsSet
$144.62​
Yakima Landing Pad 12 Sets
$143.90​
Yakima Skyline Towers
4​
$244.95​
Yakima Round Bar SL Adaptors
4​
$30.00​
$144.62​
$143.90​
4​
$244.95​
4​
$30.00​
cool solution. what impact on mpg did you notice and how's the noise? I think the OP definitely had some noise and serious mpg loss if he went 75-80+ mph.
you've got some decent $ in the hard tonneau but I think this still works without it?
also this might be a stupid idea and maybe you already thought of it or even tried it. but I wonder if there were would be any difference in noise & mpg if the box were mounted in reverse? the nose is out of the windstream a lot more than the tail, so perhaps flipping it would be a benefit.
