Mikeetch
Michael
2023 Alto Blue XLT Hybrid Maverick
Bigger vehicles. It will probably be more in line with the $500 for upcharge colors currently.
Hopefully, that would be my substitute for Alto blue @$500
svogt302
NJ
2012 Mustang Boss 302, 2019 Ranger
It's a ~$100 Ford Accessory easily added at/after delivery...
That accessory stinks... On my 3rd one in a Ranger.
kenlusaka
Ken
FL
2016 Jeep Cherokee V6 4WD
I thought so too, but the upcharge on Bronco for HPR is the same with Maverick at $500. So, it seems more likely that Azure Gray will also be a $1,000 option... That really is O-U-C-H.
svogt302
NJ
The wireless non-factory keypad has a battery that is not replaceable. When it dies, the keypad will be useless.
The battery is replaceable in my Ranger
OleFordGuy
Must be something different about the add on ones then, I've had the factory ones on numerous fords over the years, never had an issue. 12 year old F150 with one, still works perfect
Bhdreadnaught
Lakeland
2019 Ford Expedition Max
2024 Maverick Order Guid [PDF]
https://www.mavericktruckclub.com/forum/attachments/2024-maverick-order-guide-pdf.113988/
Product changes:
Pass-thu rear window deleted, 400W INVERTER no longer a add-on option. More...
Download the entire order guide:
I swear it’s like Ford looked up my build sheet and just started stabbing my truck build.
XL
Hybrid… let’s make an upcharge
Area 51…. Too many people like that color, let’s ditch it… here is another color but not for your trim
hitch… good luck finding a hitch
+400 watt inverter… done with those
Cp360 … thankfully still seems available as with my 23’ order,
svogt302
NJ
23MAVLariatAWD
VA
RECEIVED '23 Hybrid Lariat Mav Oxford White BAP
If you have a keypad you will use it -- it's really useful esp when it's in battery conserve. I use mine every day because it's easy!
