Keys can be locked in the truck.
If you do not have the trucks permanent key code (came with truck on small tag). It is printed on the BCM located in passenger floor area on the side nearest the door. OR you can get it with both keys in key start trucks by inserting one of the keys without foot on brake turning to accessory waiting about 4 seconds when dash finishes "to start put foot on brake" pop up. Remove key then place the other key in and turn to accessory within five seconds (no foot on brake) wait for several seconds for a popup window which will say key code is nnnnn!
IF you have keyless start place the two keys in the bottom center of the console well pushing the start button without foot on brake sequencing like above example with the keys the button pushing is like turning key on and off!
brlr2000
Bruce
2024 Maverick XLT Hybrid
Yes order one from dealer or Ford online.
To program enter the truck key code and within 5 seconds push the 1-2 key on keypad then within 5 seconds enter the numbers you want to use followed by pushing the 1-2 key on keypad also within 5 seconds. = BINGO you have programmed key code. (After you push the 1-2 button saving your desired key code the locks should cycle demonstrating success).
Awesome. Thanks for the detail!
Kagiso
Patrick
US
2001 Toyota Tacoma PreRunner
Because my 2024 Mav locks itself sometimes (arbitrarily), I'm careful to take my phone with me in the summertime when I want to keep her cool running. Otherwise, I take the key with me. Never know when it's gonna happen (arbitrary for real). Thankfully, i always had my phone with me when it surprised me a few times. The keypad sounds add-on great.
What year Mavericks are you referring to?
22,23,24. I assume 25,26 also
The process you posted, is what I would use if I wanted to change my numbers.
2024 25 and 26. Do not have a wired keypad. Ford Mavericks with a wired keypad are the ones with a keypad code number.
The question that was asked was. If he bought a remote wireless keypad and stick it to the outside of the Maverick, is he able to program it. That process is done by the dealership.
Because I'm a 2023 with a wired keypad I get one of these.👇🏻👇🏻
Ford Maverick Keys can be locked in the truck. IMG20260202174010
If you don't have a keypad you don't get one of these.
patenter
Frank
Meredith NH
2024 Maverick Lariat
When I try to buy the keypad from the Ford website, it forces me to send it to the dealer and charges me for installation.
That is correct that was covered in earlier posts.
Check out post #50
You can certainly tell the dealer where you want to keypad mounted, but they have to do the programming.
The link shown 👆🏻👆🏻is the instructions for a wired keypad OR changing the code on an already programmed keypad
See my picture
Ford Maverick Keys can be locked in the truck. IMG20260202175622
The OP doesn't have any keypad on his truck whatsoever. Therefore he doesn't have a little tag with a keypad security code on it.
He wants to add a keypad the only way that he can do this is with a stick on wireless remote keypad that Ford has the program. Wireless keypad pictured below.
Ford Maverick Keys can be locked in the truck. Screenshot_2026-02-02-17-43-58-62_40deb401b9ffe8e1df2f1cc5ba480b12
Hmmmm?
I'll check this out. It is logical that at least another step might be needed to do a one time mating if generic key pad. Seems like I read somewhere that someone had added a keypad using the process like programming a third fob or adding a fob when you had only one fob....??? Take a day or two for Brazil nuts to find that memory???
Found this
Thank you for posting James👍🏻👍🏻
That seems to confirm that programming of the wireless keypad has to be done by the service department or as Tim pointed out possibly a forscan unit
Thank you for posting.
That seems to confirm that programming of the wireless keypad has to be done by service department or possibly a forscan unit.
Saw additional short bad video of someone installing wireless keypad, who had computer screen open (was not forscan, I think) maybe Ford (?) clicked on line and was prompted to enter serial number of wireless keypad. I could not get link to work for that.....
