- Jul 16, 2021
- Springfield, MO
- Ford Ranger
- Engine
- 2.5L Hybrid
2022 Ford Maverick vs. 2022 Ford Ranger Comparison | Kelley Blue Book (kbb.com)
11/16/2021 10:00am
The choices for a less-than-full-size Ford pickup just doubled. Thanks to the new 2022 Ford Maverick and 2022 Ford Ranger, you now have two options to get the job done. Here’s how they compare.
2022 Ford Maverick Starting Price: $19,995
Above Average: Standard hybrid powertrain; exceptional mileage; available all-wheel drive; max 4,000-pound towing; 1,500-pound payload.
Below Average: Hybrid model not available with AWD; some advanced safety features optional, 4-door crew cab only; even on top trim levels.
Consensus: An old name now graces a new compact pickup truck. The Maverick rides on an SUV-style unibody platform it shares with its Bronco Sport and Escape siblings. It is standard with a hybrid powertrain, has real truck capabilities, and can actually go off-road. Best of all, it has a price of entry around $20,000.
2022 Ford Ranger
2022 Ford Ranger starting price: $25,285
Above Average: Powerful standard engine; can tow 7,500 pounds; carries 1,905-pound payload; standard forward-collision warning; good fuel economy; SuperCab and SuperCrew Cab body styles.
Below Average: One engine and transmission choice; somewhat stiff ride; due for an update in 2023.
Consensus: The Ranger features high-tech infotainment and safety features in addition to a great tow rating and best-in-class payload. New for 2022, the Splash trim package joins the Tremor Off-Road package as available options.
Maverick vs. Ranger: Big Things in Smaller Packages
The Ford Maverick is all-new for 2022 and marks the Blue Oval’s return to the true compact pickup segment. It features an easy-on-the-wallet entry price of $19,995, a unibody platform for an SUV-like ride, and a standard hybrid powerplant under the hood. It competes with the slightly smaller Hyundai Santa Cruz.
The Maverick is powered by a front-wheel-drive 2.5-liter Atkinson-cycle 4-cylinder engine with an electric motor-generator. Producing 191 combined horsepower and 155 lb-ft of torque, it achieves an EPA city rating of 42 mpg.
For those wanting more power, consider the 250-horsepower 2.0-liter turbocharged inline-4 EcoBoost engine with standard front- or available all-wheel drive. Matched to an 8-speed automatic transmission, it is capable of 23 city/30 highway mpg. AWD may chip away at that with an estimate of 22 city/29 highway mpg.
Trim levels range from XL, XLT, and top-line Lariat models with the standard hybrid powertrain. We recommend the required 2.0-liter turbo EcoBoost engine if you plan to tow, which adds $1,085 to the price. All-wheel drive adds another $3,305, along with other options.
Inside is plenty of storage space for water bottles and other items that are part of your daily kit. Rear seating folds up to reveal two storage bins. (The hybrid only has one since the battery pack takes up the other.) An 8-inch touchscreen display with Apple CarPlay and Android Auto are standard, as is FordPass Connect with an embedded modem and Wi-Fi hotspot for up to 10 devices. A Bang & Olufsen 660-watt sound system is also available.
The Maverick’s Flexbed truck box is 4.5 feet long and wide enough for 4×8 sheets of plywood with its adjustable tailgate. A low lift-in height makes loading easy, and the bed can be equipped with 12-volt power. Two 110-volt outlets are optional.
Ford Ranger
The Ford Ranger carries on for 2022 in the midsize truck segment as a highly capable and adaptable midsize truck that makes everyone forget the previous Ranger. It’s powered by a turbocharged 2.3-liter inline 4-cylinder engine making 270 horsepower and 310 lb-ft of torque.
Using a 10-speed automatic transmission, Ranger moves with authority regardless of whether it is equipped with rear- or all-wheel drive. By the way, all-wheel drive will set you back about $4,000, which seems a bit steep.
The 2022 Ranger offers a choice of SuperCab or larger 4-door SuperCrew options with two different bed lengths. If you haul passengers regularly, we recommend the SuperCrew over the tight-fitting SuperCab. If you tow, the Tow-Optimized Blind Spot Monitoring System, which extends its vision to include whatever is being towed behind, is a good bet.
Ford’s Co-Pilot360 safety suite is available on all models, but you will pay for it on the XL. It is standard on the XLT and Lariat trim levels.
For 2022, the Ranger gets a new Splash edition, available with exclusive orange and black side graphics and black 18-inch wheels. Inside is orange accent stitching, steering wheel, shifter knob, and parking brake boot. It’s a throwback to the 1990s when the Splash edition Ranger last appeared.
Similarities
Both are competent pickup trucks from Ford Motor Company. The choice for a buyer is deciding how much truck they may actually need.
2022 Ford Maverick Advantages
Standard hybrid power; available turbo-4 and AWD; lower entry price; SUV-like ride.
2022 Ford Ranger Advantages
More power; nearly class-leading towing and payload; comfortable crew cab.
Which One is Right for Me?
The new 2022 Ford Maverick offers compact dimensions in a fuel-efficient and affordable package. It even has some off-road chops that will take you off the beaten path in SUV-like comfort, thanks to its unibody construction.
The 2022 Ford Ranger may be showing its age but offers nearly class-leading capabilities, not to mention a comfortable SuperCrew cabin. Both are equally good on and off-road.
11/16/2021 10:00am
2022 Ford Ranger
Ford Ranger
Similarities
2022 Ford Maverick | 2022 Ford Ranger | |
Popular Powertrains | ||
Engine | 2.5-liter I4 Hybrid | 2.3-liter turbo I4 |
Horsepower | 191 hp @ 5,600 rpm | 270 hp @ 5,500 rpm |
Torque | 155 lb-ft @ 4,000 rpm | 310 lb-ft @ 3,000 rpm |
Transmission | CVT automatic | 10-speed automatic |
Fuel Economy | 37 mpg (42 city/33 hwy) | 23 mpg (21 city/26 hwy) |
Also Available | 2.0-liter turbo I4; 8-spd automatic; AWD | AWD |
Specs | ||
Warranty | 3 years/36,000 miles | |
Powertrain Warranty | 5 years/60,000 miles | |
NHTSA Safety Rating | n/a | 4 stars |
Max Seating Capacity | 5 | 5 |
Wheelbase | 121.1 inches | 126.8 inches |
Overall Length | 199.7 inches | 210.8 inches |
Width | 72.6 inches | 77.8 inches |
Height | 68.7 inches | 71.1 inches |
Turning Diameter | 40.0 feet | 42.0 feet |
Headroom, Front | 40.3 inches | 41.0 inches |
Headroom, Rear | 39.6 inches | 38.3 inches |
Legroom, Front | 42.8 inches | 43.1 inches |
Legroom, Rear | 35.9 inches | 34.5 inches |
Shoulder Room, Front | 57.3 inches | 56.7 inches |
Shoulder Room, Rear | 55.6 inches | 56.3 inches |
EPA Passenger Volume | 100.3 cubic feet | 97.6 cubic feet |
Max Payload | 1,500 pounds | 1,905 pounds |
