It's Happening. NHTSA 23V380
flashfearless
Alan
2022 Ford Mav Lariat Hybrid,2014 Ford Edge Limited
Best to sell now before value drops and get a Tacoma for 20k more 😉 I’m not happy abt this.
Keeping mine until it won't go no more
CurtisB
2023 Maverick XLT Hybrid
Some people got really bad Maverick's and had no choice but to sell it. Others haven't. I'm one of those who is satisfied so far, even with the "sleep" issues and recalls. It's a new truck. Just installed an AGM battery so hopefully my truck won't be going to sleep anymore.
homerdog
Jack
St Johns, MI
2022 Maverick Lariat Hybrid
Look on the bright side, you could've bought a Cybertruck
Mav_RICK
Rick
Arizona
Ford F150
Back in the day we didn’t need software to tell us to pull over and shut the engine off when we heard a loud knocking and smoke rolling out from under the hood.
personally think it’s a big nothing burger.
clofan
Jacob
Arkansas
Same here, very happy with the truck but I haven't had any recalls done yet. Although the sleep issues are pretty annoying and more frequent, now that I've shorted my commute from 25 miles down to 3. I hope the AGM battery helps you!
clofan
Jacob
Arkansas
I'm up to 5 recalls now!! Suppose I should make an appointment. Nearest Ford dealer is about an hour away, just a pain to coordinate that.
D Janke
Phoenix AZ
2022 Ford Maverick Hybrid Lariat !
What is an AGM battery? I'd love to put an end to the constant sleep mode notices too.
clofan
Jacob
Arkansas
Different battery chemistry than a 'normal' lead-acid. Supposed to last a little longer between charges, able to be mounted in any orientation-- that makes them real popular with the jeep and motorcycle crowd. Also a lot more expensive!
D Janke
Phoenix AZ
Ah yes ... Just spoke to my local shop and they explained they are a sealed Gel technology, new style, and handle the modern electronics heavy vehicles better.
and ah ya .... $369 + tax for the Interstate version of the AGM for my '22 Mav Hybrid.
Costco is always a good go-to, so I looked up the AGM model for my truck, and it came back with "we don't have it"......
BostonFordFan
Boston, MA
Don't get your hopes up - I doubt the software update fixes the engine problem. Likely all it does is make sure you don't try to keep driving when the engine creates a new inspection port. Perhaps they trigger a shutdown based on a sudden oil pressure drop. The goal being to try to prevent a fire breaking out when someone keeps driving after it happens.
This is a safety recall to prevent fires. There is no software update that will fix an engine that is destined to fail because of bad assembly or bad components. The best they can do is try to keep someone from getting killed when it lets go. And that is all NHTSA cares about.
Here is the link if anyone wants to read the whole thing and not a cropped version
https://static.nhtsa.gov/odi/rcl/2023/RIONL-23V380-8214.pdf
The key bit is in red:
Right now, doing the correct thing when the engine blows is voluntary, and requires someone to notice, and recognize the problem for what it is, and know what to do when it happens. The software update probably eliminates any potential for the operator to misunderstand the issue and not shut down the engine.
On the cars that need parts to effect this "fix", they probably need parts to better detect the condition when it happens and relay that info to the PCM.
That is just my hunch.
This is all correct. I did this recall and it just puts a warning sign on the dash to alert driver of potential shutdown. I was told by my dealer that 1% of the hybrids out there from '22-23 that are effected-meaning about a 1,110. But they don't know and it would require a new engine block which they are not doing. This all reminds me of the cheap fix they did on the pinto. That didn't go well.
AlsMaverick
Allen
Cincinnati
2024 Maverick Lariat FX4 w/4k Tow Build Date 12/5
That's not true. The Pinto problem is VERY exaggerated. The fix worked perfectly. Get your facts straight.
FloodingdowninTX
Fusion
Your dealer told you something.
