Issues / problems with the hood release mechanism?
GlennTX
Glenn
Burkburnett, Texas
2022 Maverick Hybrid, 2025 HD Street Glide Ultra
Has anyone had any issues/problems with the hood release mechanism?
The cable came off the release handle so when I pulled the handle the entire cable moves instead of the inner cable attached to the latch. My dealer looked at it and ordered a new handle mechanism. (and of course it's back-ordered). I can still get under the hood by using a pair of pliers to hold the cable while pulling the handle.
The Weatherman
Dean
KY
I had that cable come off the back of the handle once, but once it was put back on no issue.
You should check to see if you can just reinsert the cable end into the connector on the handle.
GlennTX
GlennTX
Glenn
Burkburnett, Texas
It's still attached the problem is the whole cable moved instead of just the center cable. :)
Sykotyk
Ohio
This can happen to any vehicle. These little plastic clips on the line that hold it in place can break or pull out. I've had it happen a couple of times in other cars. Just a pain in the butt.
Mavonorder
Pete
Camry
The handle for the hood release is weak to say the least. I make sure to grab the handle as close to the pivot point as possible so as to reduce the stress put on the handle itself because I don't want the handle to snap off on the future. I do the same for the glove box handle which is extremely flimsy.
Mav4him
Carl
Fredericksburg VA
Mine just popped off yesterday. Hopefully I can fix it tomorrow after reading this thread.
btas
Northern New York State
Ford Maverick, Ford Mustang, Ford Escape
Mine just popped loose and I can no longer open the hood. How hard is it to remove the panel trim by the hood release without damaging it?
GlennTX
GlennTX
Glenn
Burkburnett, Texas
I could never figure out how to get the handle off and it seems to be attached to the side panel.
I was able to grab the cable with a pair of pliers in order to hold it while pulling the handle. My dealer ended up changing a part. They told me the hood struts I put on is what caused it. They paid for the repair but told me they would not replace another one.
btas
Fixed mine today by removing the top trim panel above the Hood Release. Loosened the one the handle goes through. Used a pair of needle nose plier to slip the cable back in where it belongs. All good now.
Ford Maverick Issues / problems with the hood release mechanism? Hood release cable loos
Ford Maverick Issues / problems with the hood release mechanism? Hood release cable fixed
Haggs
Paul
Milton
2024 Ram Rebel 2500, 2023 Maverick, 1981 Yamaha Midnight Maxim
Thanks for the post. Easy fix if you know what your looking for. Much appreciated
pa-outdoorsman
PA
2022 Maverick XLT, EB, LUX, FX4, 4K, Cactus Gray
Guys, this thread just saved my life. Thank you!
juekerus
Wow, I am having the same problem with the strutts I installed, I will try the fix! Thanks!
grumpyunk
tom
georgia
A design for ease of assembly with little assurance the cable sheath will stay in the slot on the plastic support.
I want to remove the lower panel that blocks direct in-line view of the bracket so I can put a zip tie around the cable to insure it won't pop out of its slot. I have had it disconnect itself twice now, with no special action on my part to cause it to discombobulate.
Has anyone seen a fix to keep the cable sheath from popping out and trying to escape?
tom
Cancunbadlands
Cancun
Cancun
If you installed an aftermarket hood struts then you need to add a hood spring, to pop it up, read some Jeep Wrangler forums
GlennTX
GlennTX
Glenn
Burkburnett, Texas
tom
I used hot glue. Have not had any issues since.
