Anyone having issues with the soft tonneau cover?
Bigsarge
My 2022 XLT Alto-Blue Mavrick Hybrid has a terrible vibration at speed..
At first i thought, flat spots in the tires, or possibly something was out of wack with the wheels.. but it's turned out to be the tonneau cover moving around.
I have tried to tighten it, to the point where there's no threads, and frankly could probably lift the back of the maverick off the ground with it.. as it's so securely attached.. but still when you are going 65-75 mph it causes a massive vibration in the back of the truck..
Has anyone else had this issue?
I purchased a Tyger Tonneau cover on Ebay ($249). It fits perfectly and doesn't have this problem. Is yours the one from Ford?
PaidEMS
Pennsylvania
2005 Saab 9-3
The problem I am having with my soft-folding cover is the "foam" at the hinges. They are tearing apart from the metal. Took to dealer today, service writer said no problem to get it replaced. Unfortunately, it has to be done by the service manager, but he is not there on Saturdays. He said to stop during the week to take care of it.
stick
2021 Jeep wrangler 4xe; 13 vw gli; 21 maverick xlt
just fyi, I love, love, love, my tri fold hard tonneau; extang eceed
RustBeltRob
Rob
Ohio
Toyota Rav4 Hybrid XLE Premium
So i ditched the Maverick, which ultimately solved all my issues with the Maverick, but for anyone curious. The tri-fold soft cover was on back-order indefinitely so i ended up just fixing it myself.
The solution to my issue was to take it apart, replace all the soft metal hardware with galvanized hardware and put it back together, that allowed me to secure it tight enough to the bed that it resolved the issue. Front plastic spring loaded claw grips included, were replaced with steel pull clips and back hardware was all replaced with galvanized bolts.
After i took it apart i realized the issue..
The rear bolts are in a T handle that is connected to a soft metal screw that with any real tension causes it to bend, and then rotate from vibration, causing the gap to change... and the cover to flop around.. The front hold points, have spring clamps, these attach to the bed rails, but they also didn't adjust right, so i ended up pulling the front clamps from a salvaged F150 Cover and retro fitted the clamps to the front of the cover.. at which point all the issues went away.. simply put they cut corners where they shouldn't have.. and for about 6.00 i fixed it..
Dano
Daniel
Washington
XL EB/AWD
Who mfg's the cover for Ford?
TheShark
I really thought one of the first things I would replace on my FE was the bed cover, originally they were suppose to come with the soft roll cover but when I got it a month ago it had the tri-fold soft cover. I've been pretty impressed with it, glad Ford switched it out.
I have on the wife's the trifold soft cover which balloons up at speed (of course). Might partially cure with air deflectors on cab. This is not our problem. The spring in the pull down retainer clips near the tail gate are too strong for the wife to operate. May try to find springs with less tension but that may create flopping. Will not know until tried is anyone aware of different attachment brackets that have a lever action?
BARTMAVERICK
Hershey PA
2022 Maverick Lariat
I have the same problem when releasing the tension on the retainer clips that hold the rear of the cover. I have to use both hands to pull down on the handle. I am going to ask the service manager if they can adjust the tension to make it easier to pull the handles down.
I adjusted the nut on the bolt that goes through the spring to the max allowed and it helped some but I ran out of bolt to loosen it further. A longer bolt would only allow maybe two more turns so I wrote that off. Wait it just occurred to me that the longer bolt would work but would stick out of the handle. The nut is a lock nut so it won't matter. This would however allow the spring to possibly rattle. I will try this though. The spring compresses when the handle is pulled down. The best cure would be a compression spring of the length with ??? Ounces less compression strength.
Two months ago, I was driving 70mph behind a gray Maverick with a soft tonneau cover. I do not know the brand of cover it was.
It was lightly "fluffing" in the wind. Soft tonneau covers look great, but the fact that soft tonneau's can be sliced open by any idiot/ tweaker with a dollar store box Cutter or knife, just for fun.
It happened to me on my old Ranger. The sad thing was, the Ranger did not have a locking tailgate. The could have just drop the tailgate and looked in.
I never lock the doors on the convertibles I owned. Therefore I never kept anything of value in the convertible's. I don't want to have to worry about where I park my truck if I'm carrying something in the bed and I want to keep it secure.
Hard bed covers or bed caps = one less thing to worry about.
Good luck
GB
I would rather be hard and secure.
Than soft and vulnerable.
