Issue with fuel tank or lines
JimBro56
Punta Gorda, Florida
2024 Lariet Hybrid
Has anyone got a yellow service engine soon light relative to an issue with the fuel tank or lines. Longer times refueling or pump Before tank is full.?
Yes about 2 weeks ago.
Dr. Ron
Ron
Mission Viejo, CA
2023 Lariat
Yes, I am taking mine in for repair Monday. Check engine light on, fuel door difficult to open, putting fuel in it will only accept about 1/2 gallon at a time.
dldjtad
Bartow, FL
2023 Ford Maverick
I had the same problem. However, the light went off on its own, and I never noticed any problems.
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
If you've been topping up at the pump instead of just stopping at the first shutoff, then you're probably filling the return vent and the charcoal canister with fuel. That will eventually plug the return airflow, causing the slow fill issue. It will also eventually harden your filler pipe seal at the tank, causing it to leak at some point.
The Real Maverick
Jack
Possible. But probably not.
It would / should return to normal after a while if you just overfilled.
If not, it's just a defect / malfunction / stuck valve.
If it were the evap canister you'd get a different warning / stored code.
JimBro56
JimBro56
2024 Lariet Hybrid
Yes, I am taking mine in for repair Monday. Check engine light on, fuel door difficult to open, putting fuel in it will will only
Yes going in on Monday too same issues
