Installing some extra tie downs, but need opinions
ladyhawkgt
J
2003 Mustang GT
does it matter which way i install these. i think they look better upside down, but if that will affect its strength or use i’ll hang them the more dangly way.
Ford Maverick Installing some extra tie downs, but need opinions IMG_3359
Ford Maverick Installing some extra tie downs, but need opinions IMG_3360
jewc75
Depends on the load.
TheWizziard
Texas-RGV
2023 Maverick XLT Oxford White
I installed these in all four of the tapped holes on each side of he bed. (8 Total)
I have the same ones you used. They are rated at 1000Lbs each. Far higher than what you should be pulling on the bed side walls. Up or down it shouldn't matter.
ladyhawkgt
ladyhawkgt
J
2003 Mustang GT
fair points.
Kagiso
Patrick
US
2001 Toyota Tacoma PreRunner
Hey J. Got a link to these? And specs on the bolts? Thanks
BBurnie
Bernard
2023 Ford Maverick Tremor
[/Quote
Hello I have the same v-rings as you, I put an rubber o-ring in the center hole of the V-rings just to hold the bolt in the center, I first had them mounted like your second picture which I liked too, but every time my maverick would rock side to side they would rattle, so I flipped them, like your first picture now they do not rattle, that's much better, as for the load just remember each mount is light duty do not winch on them to tight as their not reinforced.
MetalsGeek
Rough
Torrance, CA 90503
Down to just the Mav
Without intentionally sounding like a smart a$$, IMHO they are called tie-DOWNS for a reason. You will almost never use them to lift something. I would install them with the ring on the top so that the bracket is more in tension than bending when you throw a rope over your cargo to secure it.
ladyhawkgt
ladyhawkgt
J
2003 Mustang GT
OwnMy Pack of 10 Cargo Tie Down Anchors Hooks, Heavy Duty Black V Rings Bolts Forged Lashing Ring 1000 lbs Capacity Trailer Anchors Hooks https://a.co/d/gooQlLF
M8 x 25mm Flanged Hex Head Bolts Flange Hexagon Screws, Full Thread, Alloy Steel, Black Oxide Finish, Quantity 15 https://a.co/d/aYMgszZ
Exranger
Northern California
Also at granger if you have one nearby
TheWizziard
Texas-RGV
Unkechaug
Maverick XL
@ladyhawkgt @BBurnie @TheWizziard How has this been working out for you? Your setups are the most similar to what I want to do. Curious how they are holding up, if you've learned anything new.
At the risk of sounding like a complete idiot, when you say ring on top, is that the first or second picture in the original post? I have looked at some many pictures of pickups online and it seems like a 50/50 split on the orientation, with everyone thinking their way is the right one.
ladyhawkgt
ladyhawkgt
J
2003 Mustang GT
i ended up doing the second pic. they did jingle jangle over every bump, but i kinda liked the sound. but i have a bedrug now and have not reinstalled them yet.
jewc75
This is mine.
Ford Maverick Installing some extra tie downs, but need opinions 20231104_160558
MetalsGeek
Rough
Torrance, CA 90503
You're quite right in that opinions are like a$$holes; everybody has one. My feelings are that the 2nd photo (bolt head below D-ring) is strongest for tying "down" a large load. If you carried compressed gas cylinders on their side you would use the floor rings instead, eh? My main reason is to reduce bending stress on the sheet metal mounting bracket, but in the real world it probably doesn't make a whole lot of difference since the Mav cannot really carry all THAT much at once. There may be other criteria that you find more important, like prevention of contact (rust!) between the floppy D-ring and the paint in the bed.
I've seen industrial D-ring brackets that use a shoulder bolt or spacer so the bracket can swivel freely (on the smooth part of the bolt) to align with whatever direction the tie goes. This would not be too hard to do with regular D-ring brackets if you were inclined. Here are a couple examples of the swivel concept, although neither is all that close to what my memory tells me I saw years ago.
Ford Maverick Installing some extra tie downs, but need opinions @junk
Light duty anchors work just fine for holding a tarp or some furniture in place. If you had to haul something like a motorcycle and wanted to compress the front suspension, it might be worth rotating your tie points so they were in tension if not already. e.g. Ring on top, ratchet strap to handlebars on each side.
Remember that if you don't mess up the Maverick, you can always change your mind later on.
