Inexpensive Tie Downs
BoskoPColtrane
Bosko
Instead of spending hundreds for the bed rail system that Ford sells, I went to Home Depot and spent less than $14 to put two of these in.
It's an M8 bolt and a medium duty D ring.
Caveat: it's only anchored on one side.
But for what I need, it'll do just fine.
Walmart has these too.
Ford Maverick Inexpensive Tie Downs 4EDF2578-4DDF-4D94-8325-9CE24DA146F1
Ford Maverick Inexpensive Tie Downs DC174445-71C8-4283-948A-4BC37F326E17
Ranch
Sacramento CA
2023 Marverick FX4 4K
LSchicago
Lloyd
IL
Why didn't you put the second bolt?
Johnkn
MD
Because there is only a single threaded hole
Some people have different ideas on doing things the right way...
LSchicago
Lloyd
IL
Johnkn
MD
And you don't want to add a second bolt?
I’m not the OP and I would never install anything that way, but it’s not my truck...
Gpp
Gil
Sanford nc
2022 ford maverick
I doubt i will haul a refrigerator or anything similar.just use common sense and you will be fine!
Ranch
Sacramento CA
I picked up my Maverick yesterday and put the D rings on this afternoon. The bolt hole in the D rings were 1/4" so I reamed them out with a 5/16" drill bit. The 8mm bolts worked fine after that.
Ford Maverick Inexpensive Tie Downs 20230616_140329
Ranch
Sacramento CA
I used these as well and like them.
Your bed looks really good.
I went with the Ford bed mat and tailgate cover. I'm surprised at how "sticky" the rubber mat is. It may be a pain if I do want to slide something around in the bed.
tonyinsd
tonyinsd
Tony
San Diego
Ford Mustang GT, Ford Maverick XL
For what I am doing, no.
It's primarily to lock the cooler I use to transport milk and other temperature sensitive items in place. It also keeps the cooler from sliding around when it's empty.
A vagrant sneaked into the garage where the truck is parked and stole the previous cooler out of the bed. The single bolt will allow me to lock it up with a cable lock. And they won't be able to pull it out.
Thoron99
NC
2023 Maverick Hybrid XL
I had picked up a pack of Ford compatible tie downs off Amazon, since I’d read that the XL was lacking some of them.
Picked up the truck this weekend and it seems to have all of the tie down points occupied. Maybe because I got the tie down rail kit that “came with” the SIBL?
Two Drings on the front floor, and 4 cleats at the rear, plus the adjustable bars.
