Tailgate tie downs
Maverickman74
Shane
Maui HI
Actually no, that isn't true. All objects fall, due to gravity, at the same rate of acceleration. If you cut the tailgate into four separate pieces, do you think they will all fall slower because each is lighter than the whole?
If you let the tailgate fall, as is, it comes down quickly.
It will get jammed up unless you add more hinges.
NJBob
New Jersey
He isnt certified but I did inspect the picture while cracking the tab on a High-Life. It'll do.🍻
Also I still dont get the purpose of the dampner. I got shoulder problems, elbow pain, wrist trouble, and arthitis in all my fingers 5 of which have been broken. 2 more than once. My tailgate still doesnt even register as a thing that needs assistance. I guess I could see a voice activated opening and closing one being useful. But dampened? For money? You could get the same effect out of an old bungee cord and a few minutes of creativity. I dunno, the world has become a strange place. And Im not even 40 yet.
If it helped with the closing I may then consider it.
Jeff D.
Jeff
Duluth, MN.
I added a folding tie-down rated a 900lbs. To replace the oem tie-down/bottle opener, that I had to remove from the driverside when I installed the strut. Both work perfectly. After having rotator cuff surgery on both shoulders that strut certainly helps. Allowing me to just unlatch the tailgate and letting it fall.
Ford Maverick Tailgate tie downs 20240529_154452
craigt502
WI
youtube.com
2025 Maverick XLT
Not perfect cause it rubs on the tailgate cable but it works. Had it extra from when I did the inside bed tie downs.
Ford Maverick Tailgate tie downs IMG_5218
Ford Maverick Tailgate tie downs IMG_5217
Ford Maverick Tailgate tie downs IMG_5216
