Last week I installed Elevate Rack and Rails ( from Realtruck ) and Ford hard tri-fold tonneau. Install took a few hours but not extremely difficult. I’m very happy with the fit and finish with only minor water leakage during rain test. I plan to add some additional weather seal to make it full water tight.
The only downside I encountered so far is that the tonneau will not completely fold against the cab when the racks are in the lowest setting. The tonneau is blocked by the crossbars. I expect I will mainly use the lowest crossbar setting and so if I happen to need the full bed access, I will need to either unbolt the cross bars to lift them high enough to clear the tonneau, or unbolt the rear towers and slide toward the tailgate to clear. It’s a minor annoyance that I don’t expect to come into play often based on my bed usage habits, but I still like this setup and wouldn’t change it had I known in advance. I attached pictures below of the rack in high and low setting height plus the tonneau blockage issue.
