Installed Elevate Racks with Ford hard trifold tonneau…. One issue to report
Hammer
Easton PA
2009 VW GTI
Last week I installed Elevate Rack and Rails ( from Realtruck ) and Ford hard tri-fold tonneau. Install took a few hours but not extremely difficult. I’m very happy with the fit and finish with only minor water leakage during rain test. I plan to add some additional weather seal to make it full water tight.
The only downside I encountered so far is that the tonneau will not completely fold against the cab when the racks are in the lowest setting. The tonneau is blocked by the crossbars. I expect I will mainly use the lowest crossbar setting and so if I happen to need the full bed access, I will need to either unbolt the cross bars to lift them high enough to clear the tonneau, or unbolt the rear towers and slide toward the tailgate to clear. It’s a minor annoyance that I don’t expect to come into play often based on my bed usage habits, but I still like this setup and wouldn’t change it had I known in advance. I attached pictures below of the rack in high and low setting height plus the tonneau blockage issue.
Ford Maverick Installed Elevate Racks with Ford hard trifold tonneau…. One issue to report 822564C1-B65D-48C0-873A-19706C3D7CC1
Ford Maverick Installed Elevate Racks with Ford hard trifold tonneau…. One issue to report F21790FE-7C49-45EB-A6F7-413665D4AD05
Ford Maverick Installed Elevate Racks with Ford hard trifold tonneau…. One issue to report 350B0D7D-3A16-4D4A-802F-948FBFA0553B
Ford Maverick Installed Elevate Racks with Ford hard trifold tonneau…. One issue to report 7D6D4066-D584-49D0-9DF5-0C2BBAD837A5
Ford Maverick Installed Elevate Racks with Ford hard trifold tonneau…. One issue to report 0AE90A60-7F90-4242-A398-D561626A1F8D
Ford Maverick Installed Elevate Racks with Ford hard trifold tonneau…. One issue to report CB3A353E-A8E1-45E1-82EE-D60CD9E2A4CD
Ford Maverick Installed Elevate Racks with Ford hard trifold tonneau…. One issue to report A70C0C33-66E3-4028-A770-653854943EF5
clavicus
Are they finally back in stock?!
They had the rails in stock but not the rack when I bought my X15 rollup cover from them in February. Alex Pendleton said he wasn’t sure if the rack would be sold separately from the rails so I held off until I could be sure to get them together.
clavicus
Do you think there is a way to cut each component to create a height level below the cab? I’m not sure how the height settings work, are there detents or something?
KenC
First
Earth.
Truck.
Dang it! So close! Maybe you can just bungee the tonneau to the rack or something.
Hammer
Hammer
Easton PA
2009 VW GTI
Yes they are now back in stock. Apparently there was some type of redesign done on the racks and they were not available for awhile but they are now back in production and being sold
Hammer
Hammer
Easton PA
2009 VW GTI
I think it could possibly be done by cutting the length of each tower post and then drilling new bolt holes. See pic below
Ford Maverick Installed Elevate Racks with Ford hard trifold tonneau…. One issue to report 4583FEBF-2A13-45D8-A93A-B5C42ABD3681
Hammer
Hammer
Easton PA
2009 VW GTI
That would work although it would still reduce the amount of open bed area.
Micheal
Micheal
PNW
2012 Escape Hy, 2014 Escape, 2022 Maverick Lariat
You can easily drill a couple of holes at a height that will allow tri-fold to fit. The vertical bars are slimply slide-in and could get any number of heights if wanted. I'd actually like to cut the bars so that they sit lower, below cab height, but I have a rolll-up, so no restrictions. I may look into finding some "pins" that I can pop out easily and change height without a wrench.
Hammer
Hammer
Easton PA
2009 VW GTI
Yeah, I’ve seen that mod posted in other thread and it looks like a good solution. I will likely go that route at some point. I like your suggestion about lockout pins for easy height adjustment. Please post if you find a good option for that.
SkeeterB
The Woodlands, TX
I have the undercover trifold. I just moved the struts to keep tonneau up against the rail.
TheSEARCH
ford
So do all hard covers work with these elevate bars? Or just certain ones.
TheSEARCH
ford
Does your hard cover have the rails, or do you need to add a set?
HRG
I myself don't have the Maverick yet. On order. But I wanted to know if any hard cover will work with the Elevate bar setup or just certain brand hard covers. Whether that is a hard roll up or tri folder.
clavicus
Theres a compatibility page that shows which models are supported, the idea is that the rail channel part is installed first on the bed rail, then the cover channels go against that. Soif another brand installs the same way there’s a chance it’ll work but I couldnt say.
https://truxedo.com/images/Elevate_Rack_System_Booklet_Jan22.pdf
Ford Maverick Installed Elevate Racks with Ford hard trifold tonneau…. One issue to report BFE4B89E-E4AF-4487-A6BC-AFBB3E75C1A8
Hammer
Hammer
Easton PA
2009 VW GTI
The simple and easy solutions often evade my brain 😎. I will definitely try that option. Thanks for the tip!
