I get hi-beam flashed from on coming traffic all the time?
papa
Lawrence
2022 Maverick XLT Hybrid
I typically drive without the need of turning on hi-beam. Its always from cars not SUV or Truck.
Is it the location of lights? I thought headlamps were aimed in such away to reduce glare/intensity for on coming vehicles?
TedTX
Ted
San Antonio TX
Nope, Maverick have the widest throw of any vehicle I have been on either side of. Very bright to look at but not in usage. Auto highbeems are default and usually turn off and on correctly most of the times but slow on turns and stops to switch between on and off.
Spook
Central KY
Maverick Lariat Hybrid
papa
Lawrence
Yes I disabled the auto hi beam feature almost immediately. Don't like it.
Thx for the share, I'm not alone!!
Goose201
Eric
Nebraska
Ford Edge
Just people showing appreciation for your sweet vehicle I'm sure
OrangeBlue
Hogtown
2022 Mav
A lot of drivers are just dumbasses.
Also, your headlights may be adjusted/aimed wrong?
Spook
Central KY
Everything plus a lot of things no one needed to know. sort the opinions at your own risk.
You got it! It will probably be repeated in this thread too. People do it over and over again.
The Weatherman
Dean
KY
I have not experienced any issue with high beam flashing. Both of my trucks have the automatic high beam sensors active and it seems to work well. Other than when in town or on lighted residential streets then it wants to switch high to low or visa versa too frequently.
As for beam alignment, they seem to be spot on.
MLA62563
Charlotte, NC
Honda Accord, Ford Maverick
Personally, I like the auto high beams a lot. They seem very consistent, and I don't think I've been flashed once in nearly a year of ownership. Maybe yours are out of adjustment? 🤔
Gullzway
OK
1968 Ford Mustang Fastback
Same, love the auto high beams. I've only been flashed(with brights) once in the 9 months I've driven my Maverick.
A Sturdy Beast
Lucky
2023 Mav XL Hybrid, Iconic Silver
The Insurance Institute for Highway Safety (IIHS) says that the Maverick low beams have a glare problem.
https://www.iihs.org/ratings/vehicle/ford/maverick-crew-cab-pickup/2022
Low beams”
“On the straightaway, visibility was good on both sides of the road. On curves, visibility was good on the sharp right curve and fair on the gradual right and both left curves. The low beams created some glare.”
“Amount glare exceeded threshold 21.7%”
2seater
Hal
Appleton, WI
Buick Reatta, Ford Ranger, Subaru Forester
I don't have my Maverick, yet, so I have no way to test, but what do the headlights look like projected on a flat surface, like maybe a garage door at 20 feet or so? Does it have a sharp horizontal cut off line and relatively dark above that or is there light scatter above the cutoff?? I know I have become more sensitive to light dazzle as I get older and especially bad now after a hi tech lens replacement for a cataract repair. Blu blockers help a little but not a cure for me.
MinntoMich
Erick
Minnesota
S10, Renegade, Impala
I'm betting your right. The intensity of new bulbs, even at low beam is strong, and the height of the beam is at eye level for the driver of a car. Not the case for someone in a truck, suv or minivan.
My first car had single low and high beam headlights that weren't halogen. No one would flash me when I took to driving with my high beams on. So many other newer cars at the time had sealed halogen beams and they were so much brighter.
I have been flashed with my low beams on driving a 15' Jeep Renegade. You guessed it, by a car. Those headlights are at eye level for drivers of those.
GPSMan
Many
I notice this a lot.
I truly think it is the switch from incandescents to LED lights.
LED's are great if you are the one IN the vehicle. Sucks for everyone else.
It's not just me.
Some report (dang if I know where, I read a lot) says headlamps are like 80% brighter now than 20 years ago.
Kind of evolved slowly over time and kinda crept up on people.
Put an incandescent car next to an LED car today, and there is a DRAMATIC difference.
Even the damn tail lamps are burning my retinas now. How many of you get "ghost dots" in your eyes from those LED stop lamps when close to someone at a stop lamp?
